At the weekend I tried to setup my suspension properly by following a few online guides. It’s not worked and is far far worse than it was!
Took the bike off piste at Inners and it was “skittering” all over the place and getting hung up on bigger bumps at the front.
Front shock is a Marzocchi 350 NCR at 160mm and these should eat up everything in their path. Not had these too long (Sport Pursuit special) and getting these spot on is why I started tinkering.
Rear is a Rockshox Monarch RC3 DebonAir.
I think the rear is probably ok. To set the sag, I switched it to open, set the rebound in the middle and sat on the bike/got off the bike. Then I adjusted the air pressure, repeating sitting, until the sag was around 30%. I made sure I bounced the shock to balance out the +/- chambers. The only thing which is isn’t right is probably the rebound. My thinking is more damping is needed to combat the lack of grip?
The fork. This has rebound damping and compression settings. Setting the compression is new to me, firstly where do have the compression when setting the sag? Then once the sag is set how do I tune the compression? It goes soft to firm. Does soft mean smoother ride, fewer little bumps? Or does soft mean the fork is soft so I get more smaller bumps??
Then there is rebound damping, which I think I need more of….
Any pointers would be much appreciated!
