I don’t think the issue is braking too much to cause premature wear – downhill I use the brakes on the tandem a lot and get really long life – thousands of miles. If anything the opposite is true
Have any of you who use these pads found that they are thicker than the pads from other manufacturers?
Its just that I’ve fitted some to my juicy 7 and it is bloody hard to get the disc between the pads.
This is after I have pushed the pistons back in and backed off the red pad adjuster knob on the lever.
You will know how you bedded them in
You will know the use they got
You will know the conditions they were used in
You will know how long they last
You will know if they make a noise
You will be able to make your own mind up from that !
The best pads Ive used have been XTR OEM sintered. One set lasted nearly a year and a half and I only swapped them out when they got really thin, but not even completely worn out.
However, their RRP is now £45! and even if they do last that long I cant justify the cost. So I use Imperial pads from MTB Direct at the moment. Seem to be lasting OK for the price but power isnt all that good. I expect to get 3-6 months out of a set.
