Dare I suggest shimano?
Will last forever if properly looked after, spares are cheap and £10 worth of cone spanners are the only tools required. (OK and a bigg-ass hex key for freehub replacement)
Other than that Hope only need a hammer and set of bearing drifts (sockets if you’re doing it on the cheap) and spares cheap enough and readily available.
As above, DT very easy to work on and look after unless you need to get at that one bearing, in which case tools or shop required.
Chris King can all be looked after with no tools other than an allen key until you want to do a proper service and get the gubbins out, then £££ for tools.
Novatec/Superstar are basically like hopes, but with more uncertainty about which spare part you actually need and availability although not too bad if you knwo where to look.
