Still getting chain...
[Closed] Still getting chain slap with a clutch mech
 SOAP
[#6166486]
My set up is 1x10 with a 40t hope cassette expander, 32 NW chainring and a MRP AMG device
Clutch mech cage has a little play (front to back) 8mm before it becomes firm/stiff.
If I manually move the chain to the chainstay there is very little resistance.
Obviously in a higher gear when descending so more chain slack.
Maybe 2x10 was not so bad after all.
Anyone got a thought on this?
Posted : 05/05/2014 12:15 pm
Your clutch needs adjusting/tightening
Posted : 05/05/2014 12:16 pm
Too much chain?
 chip
Is there any difference between the resistance when the clutch is turned off to when it is turned on.
Posted : 05/05/2014 4:56 pm
Would say you need to remove a couple of links from your chain. Show us a pic of your mech when on the t-rex.
Posted : 05/05/2014 5:20 pm
Chain & mech is too long. I have a 1x10 set up with a short cage mech and its not a clutch. But I get no chain slap at all.
Its not rocket science, just remove the excess.
Posted : 05/05/2014 5:35 pm
 SOAP
Removed air from shock to get full squish and I don't think I can remove anymore links.
I've tightened the clutch and it's is a fair bit stiffer so fingers crossed that's it sorted now might even take the MRP off.[URL= http://i737.photobucket.com/albums/xx19/geoff1_photos/F9E4F9B5-8231-495C-8F94-812E788CDDC4_zpss0bmam6k.jp g" target="_blank">http://i737.photobucket.com/albums/xx19/geoff1_photos/F9E4F9B5-8231-495C-8F94-812E788CDDC4_zpss0bmam6k.jp g"/> [/IMG][/URL]
Posted : 05/05/2014 5:46 pm
 chip
That looks good to me.
Posted : 05/05/2014 6:10 pm
Yep don't think your going to get any shorter there..well not much anyway.
Posted : 05/05/2014 7:28 pm
Same issue for me - chain is as tight as it will go, but there's slop in the clutch mechanism - I had a look inside and it's play in the mount for the roller bearing. Gives just enough slack for the chain to rattle around a lot, but not enough for it to fall off (so far!).
(XT shadow+ mech running 2x9 with an XO 9s shifter & spacer)
Posted : 05/05/2014 7:58 pm
