OK, so here is the low down on the new Pegasus proto. Geometry is roughly between a current Swift and a Buzzard. 70deg head angle with a sagged 120mm fork, 435mm chainstays, other critical dimensions much the same as the current Swifts. It has a full size set screw type EBB. Tubing is much larger diameter than the old Pegasus. Headtube is 44mm ID (tapered/straight compatible) and seat tube is for a 31.6mm post. Frame weight is 1.75kg (3.85lbs).
Those are the numbers, how does it ride? I can honestly say it is the best mountain bike I’ve ever ridden. Pedalling it feels solid and stiff, all effort is directed forward, this is definitely no Ti noodle. This stiffness translates into a very assured and confident feeling when descending – it’s not quite as point and blast as a Buzzard, but this is intended more as ‘capable xc’ rather than ‘all mountain’. However that vaunted Ti zing is still there, it is comfortable and fairly smooth riding. Overall, I love it and look forward to getting folks on them. I am just finalising details with the factory now but the rough plan is to have them here around October time. Prior to that I will be running a kickstarter-ish type deal whereby you get a healthy discount for putting your money down now for delivery then.
