As per my last thread, I have an M785 crankset on my bike just now. In advance of swapping to 1×10 I’ve been out (to the garage/work stand) to see how smooth it is in the big ring and the big sprocket. It didn’t seem great to me, the chain looked like it wanted to come off the sprocket, and it definitely sounded a little more scrapy than it did on the other smaller sprockets.
I therefore wonder if, rather than bolt the NW ring straight onto the inside of the crank – where the 38t ring sits now – it might be better to get longer chainring bolts and spacers, to move it in a few mm, so it’s as close as possible to being in line with the middle of the cassette? But by how much? I’m not sure what the gap between chainrings is, looks maybe around 8mm. Should I go for as much as a 4-5mm spacer and corresponding bolt? And who can I get longer bolts plus spacers from? (CRC/Wiggle etc. it’s the spacers Imnot seeing easily).
The Shimano tech doc parts list says the outer bolts on M785 are M8x7.
I’m guilty sometimes of being a bit too much of a perfectionist so apologies if that’s the case here 🙂
