I have always managed to make my wheels and tyres tubeless with different rims and tyre combinations.
Until now.
DT Swiss BR 2250 rims, had great and easy success with Jumbo Jims, Maxxis Mamoths, 45 NRTH Husker Du.
All fitted and inflated with the use of the Airshot canister, relatively simply.
Wanted to fit a Surly Nate 120 tpi on the front wheel for a bit more grip.
The inside diameter of the tyre is slightly larger than the rim, and the tyre will just slide over the outer rim with ease. Even when you can get the tyre onto the rim and stay there, when inflating the air just rushes out .
Putting a tube inside to seat the tyre on to the rim doesn’t work either.
Inflated the tyre and inner tube to 30 psi and left overnight to seat.
As soon as you release the pressure to remove the inner tube, the tyre just separates from the rim and the tyre almost falls off the rim.
Only way seems to run with an inner tube, but in the event of a puncture I am concerned that the tyre might easily just roll off the rim, and leave me with some close foliage inspection.
