Viewing 25 posts - 1 through 25 (of 25 total)
  • Someone please help me with my PC problem – suspected virus
  • nasher
    My PC is slowly grinding to a halt. A lot of programs dont seem to run (or is not responding)
    I have downloaded other virus check software (my windows one care wont load). Although they downloaded OK I cannot seem to run them
    also when i go into services, many of them have stopped i.e printer but get the Error 1053 message, again after reading the web I still cannot get it to work
    I think i have a virus but can anyone reccommend one thatw ill actually start up?
    Ta
    Frankenstein
    Could be so many things!
    My PC slowed down as the hard drive was on its way out.
    If the virus killer didn't find anything, can you copy your files to external drive or usb and reinstall the Op.System?
    If so make sure you have all the drivers to get online too.
    You might not need to do this!
    1st Go into task manager and see whats using the cpu?
    sofaking
    what about going into your set up and start you pc from an earlier time/date .
    worked for me
    nasher
    sofaking…how do i do that? i run vista
    Cougar
    Download Malwarebytes, install, update, run it, save a log, let me know what it finds.
    mboy
    Cougar – Member
    Exactly what he said…
    Malwarebytes is the only software I trust to get rid of infections on my computer, having tried so many others and nearly lost a computer because of a really nasty Trojan!
    nasher
    Cougar
    I have downloaded this earlier, problem is I cannot get it to run, I click on it and nothing happens….This happens to all the anti virus programs i have downloaded…
    EDit: windows explorer is now "not responding" any other way I can open it?
    Cougar
    Rename it from MBAM to something else and try again?
    Cougar
    … if that doesn't work, run rkill first. If rkill won't run either, try this alternate version here – it's the same file renamed.
    nasher
    I got this from Rkill:
    This log file is located at C:\rkill.log.
    Please post this only if requested to by the person helping you.
    Otherwise you can close this log when you wish.
    Ran as admin on 29/07/2010 at 20:35:33.
    Processes terminated by Rkill or while it was running:
    C:\Users\admin\Desktop\iExplore.exe
    Rkill completed on 29/07/2010 at 20:35:36.
    Cougar
    Hm.
    Will MBAM run now? Like I say, you might have to rename the file first.
    Cougar
    Ah – it terminated itself. It does that, no worries.
    nasher
    THis was the log… it found 25 on the quick scan……
    Malwarebytes' Anti-Malware 1.46
    http://www.malwarebytes.org
    Database version: 4052
    Windows 6.0.6001 Service Pack 1 (Safe Mode)
    Internet Explorer 7.0.6001.18000
    29/07/2010 20:49:45
    mbam-log-2010-07-29 (20-49-45).txt
    Scan type: Quick scan
    Objects scanned: 130916
    Time elapsed: 6 minute(s), 11 second(s)
    Memory Processes Infected: 0
    Memory Modules Infected: 0
    Registry Keys Infected: 0
    Registry Values Infected: 0
    Registry Data Items Infected: 0
    Folders Infected: 0
    Files Infected: 25
    (No malicious items detected)
    Folders Infected:
    Files Infected:
    C:\Program Files\FxVdx30.dll (Spyware.OnlineGames) -> Quarantined and deleted successfully.
    C:\Program Files\hhrashlp.dll (Spyware.OnlineGames) -> Quarantined and deleted successfully.
    C:\Program Files\HHWMPrxy.dll (Spyware.OnlineGames) -> Quarantined and deleted successfully.
    C:\Program Files\MDLL32.DLL (Spyware.OnlineGames) -> Quarantined and deleted successfully.
    C:\Program Files\MumaIpl.dll (Spyware.OnlineGames) -> Quarantined and deleted successfully.
    C:\Program Files\MumaIplA6.dll (Spyware.OnlineGames) -> Quarantined and deleted successfully.
    C:\Program Files\MumaIplM6.dll (Spyware.OnlineGames) -> Quarantined and deleted successfully.
    C:\Program Files\MumaIplP6.dll (Spyware.OnlineGames) -> Quarantined and deleted successfully.
    C:\Program Files\MumaIplPX.dll (Spyware.OnlineGames) -> Quarantined and deleted successfully.
    C:\Program Files\MumaIplW7.dll (Spyware.OnlineGames) -> Quarantined and deleted successfully.
    C:\Program Files\PlayRIpl.dll (Spyware.OnlineGames) -> Quarantined and deleted successfully.
    C:\Program Files\PlayRIplPX.dll (Spyware.OnlineGames) -> Quarantined and deleted successfully.
    C:\Program Files\qtmlClient.dll (Spyware.OnlineGames) -> Quarantined and deleted successfully.
    C:\Program Files\SAMSIG.DLL (Spyware.OnlineGames) -> Quarantined and deleted successfully.
    C:\Program Files\samsigA6.dll (Spyware.OnlineGames) -> Quarantined and deleted successfully.
    C:\Program Files\samsigM5.dll (Spyware.OnlineGames) -> Quarantined and deleted successfully.
    C:\Program Files\samsigM6.dll (Spyware.OnlineGames) -> Quarantined and deleted successfully.
    C:\Program Files\samsigP5.dll (Spyware.OnlineGames) -> Quarantined and deleted successfully.
    C:\Program Files\samsigP6.dll (Spyware.OnlineGames) -> Quarantined and deleted successfully.
    C:\Program Files\samsigPX.dll (Spyware.OnlineGames) -> Quarantined and deleted successfully.
    C:\Program Files\samsigW7.dll (Spyware.OnlineGames) -> Quarantined and deleted successfully.
    C:\Program Files\thunk16.dll (Spyware.OnlineGames) -> Quarantined and deleted successfully.
    C:\Program Files\thunk3216.dll (Spyware.OnlineGames) -> Quarantined and deleted successfully.
    C:\Program Files\ZIPDLL.DLL (Spyware.OnlineGames) -> Quarantined and deleted successfully.
    C:\Program Files\setup.exe (Rogue.Installer) -> Quarantined and deleted successfully.
    nasher
    That was done on a fast scan… However when I do a full scan the program stops responding..
    Cougar
    Right. That could be worse.
    Reboot, then run it again in full mode.
    Once we've got this cleaned, we need to look at patching. You want SP2 for Vista as a bare minimum, ideally you need to be running Windows Update until it stops updating.
    nasher
    its now scanning 20 mins and counting..
    Cougar
    Yeah, it'll take a while. Should've thought, it'd have been quicker if we'd done a temp file cleanup first, bit late now. Ho hum.
    nasher
    Scan is done…. no further viruses found..
    So what do i do now.
    Database version: 4367
    29/07/2010 22:12:38
    mbam-log-2010-07-29 (22-12-38).txt
    Scan type: Full scan (C:\|D:\|E:\|F:\|H:\|I:\|J:\|K:\|)
    Objects scanned: 336225
    Time elapsed: 1 hour(s), 4 minute(s), 5 second(s)
    Folders Infected: 0
    Files Infected: 0
    Folders Infected:
    Files Infected:
    Cougar
    Cool.
    Right. Download and run TFC.
    Run Windows Update, apply all the patches it gives you. SP2 for Vista should be a priority.
    Get Secunia PSI. This will scan for software which has updates available other than Windows itself. Prioritise Adobe updates, old Flash etc are common points of entry for malware.
    What are you running currently in the way of Antivirus?
    Cougar
    Oh,
    Go into Uninstall Programs (or whatever it's called in Vista, can't remember exactly). Uninstall anything you're not using, specifically IE toolbars and crap that's got installed with other things along the way.
    -Liam-
    What computer is it?
    Could possibly have a back up partition on the hard drive.
    Back up your files and start a fresh. Then sort a proper anti virus.
    All these programs that everyone suggests don't do the job properly and eat resources.
    chewkw
    Also try to scan in Safe Mode.
    Cougar
    Only if you don't know what you're doing.
    nasher
    Hey Cougar, I clicked on your TFC link but what exactly do I download?
    also I tried to load service pack 2 but it wouldnt install.
    also tried windows update but when i click on it nothing happens…like alot of the other programs…
    Cougar
    Ah, looks like they've updated the website and changed the links, sorry. Try this
    When you say SP2 won't install, what exactly happens?
    Ignore the other patch stuff I suggested for now, we need to make sure it's clean first.
The topic ‘Someone please help me with my PC problem – suspected virus’ is closed to new replies.
