How have you reached this conclusion…
I’ve decided the front of the Codeine needs slacking off a bit,
When you’re still (after in fact) asking this question?
What effect am I likely to get from a slackset ? More stability at speed etc.
Shouldn’t you try to get an understanding of what geometry changes will do to your bike before you go deciding to mess with it? I’m not saying a degree or so off you HA is a bad idea, just that you appear to have jumped the gun a bit, and without explaining what you think is wrong about the way it currently handles. There is of course a chance that it’s something else that’s causing whatever that issue is.
Sorry, don’t know what came over me there, of course the default STW answer is “MOAR SLACKERER!”, it fixes everything, for trails everywhere
Not at all mate I know where you are coming from.
So on some of the twistier and steeper stuff I’m finding that I’m steering to quickly and then backing off and end up messing the corners up. I’m not sure if it’s also due to the 800mm bars as well.
The 529 felt much more stable at speed compared to the codeine.
I understand the offset bushes drop the bottom bracket height and slack the bike off that way just not sure how else a slackset would affect the bikes geometry.
It’s all a learning curve.
