Sirloin steak - coo...
[Closed] Sirloin steak - cooking tips!
[#4278818]
Got 2 cracking steaks from the butcher today but to be honest im usually a chuck them in the frying pan for 2 minutes kinda guy. But its a shame not to give these the full treatment.
Marinade?? how long etc.
What ideas have u got??
Posted : 20/08/2012 6:22 pm
No marinade, keep them out of the fridge and season heavily a few minutes before you cook them to your liking. If it needs a sauce or marinade it's shit steak.
Posted : 20/08/2012 6:24 pm
Cool, easy peasy 🙂
Posted : 20/08/2012 6:26 pm
No marinade, keep them out of the fridge and season heavily a few minutes before you cook them [s]to your liking.[/s] rare. Anything else is a waste of good cow!
This is true, however. Also, rather interesting to see that the word shit is apparently not on the swear filter. That's a bit shit if anyone's ever had a warning for using shit in the past. It might make them feel shit about it. 😉
Posted : 20/08/2012 6:56 pm
Really hot buttered pan. Flip once only. Cracked sea salt after cooked.
Posted : 20/08/2012 7:00 pm
cook it Heston style. It really works......
http://singletrackworld.com/forum/topic/inspire-me-meal-ideas-for-fillet-steak
Flip [s]once[/s] regularly while coking to ensure it's evenly cooked [s]only.[/s]
Good call on the salt, though. Nom. Nom. Nom.
Posted : 20/08/2012 7:01 pm
When i cook steaks i put oil, salt and pepper on the steaks and leave them to sit on a plate and get to room temperature. I will then get the griddle pan as hot as i can then cook as required.
Posted : 20/08/2012 7:03 pm
Cheers theotherjonv, great thread. So many ideas 🙂
Posted : 20/08/2012 7:07 pm
Make sure it#s room temp before you cook it. season heat pan with oil and nob of butter, cook evenly on both sides until the desired style. done.
Posted : 20/08/2012 7:17 pm
Don't forget to let it rest after cooking 😉
Posted : 20/08/2012 7:22 pm
Sear on both sides then bang it in the oven under tin foil.
Dribbly good!
Posted : 20/08/2012 7:24 pm
water bath + blow torch
[url= http://www.seriouseats.com/2010/03/how-to-sous-vide-steak.html ]sous-vide[/url]
Posted : 20/08/2012 7:35 pm
Drac has it. You can also use way much more salt than you imagine as long as you don't do it too far in advance.
Posted : 20/08/2012 7:43 pm
As above, season with lots of salt and pepper a room temperature steak. Get griddle/fry pan red hot(and I mean RED HOT!) With a pair of tongs, sear the fat side for a few minutes to get some colour then place the steaks face down on the griddle for about 2 minutes per side(depending on thickness/level of doneness) Flip and repeat. When done take off and rest(the steaks, not you :D) while you finish cooking your chips etc. Nom nom
Posted : 20/08/2012 7:52 pm
No steak needs a sauce or marinade! But a good sauce makes excellence even better! Don't oil the pan - rub the steak with oil and place on a non-stick griddle or in a non-stick pan.
Posted : 20/08/2012 7:55 pm
Oh and season really well before cooking!
Posted : 20/08/2012 7:56 pm
Crush a load of peppercorns and press them into the steak before cooking.
Fry in a mix of butter & oil
Take out & let rest. Deglaze pan with favourite spirit or wine. Stir in double cream. Voila - Steak au Poivre.
Posted : 20/08/2012 8:10 pm
CFH - you have disappointed me. No flaming of sirloin steak? No suggestions that it's peasants food and no suggestions for fillet steak. Recession biting hard?
Posted : 20/08/2012 8:17 pm
Glupton, men eat sirloin. Fillet is for the ladies. 😉
Posted : 20/08/2012 8:18 pm
CFH - You've changed.
Posted : 20/08/2012 8:25 pm
No to pepper, it burns in a hot pan. Get to room temp, season with salt and pan fry to your desired state. Rest and season.
Posted : 20/08/2012 8:26 pm
Nope. Always been a sirloin man.
Bought here, preferably.
As I did this weekend. Multo-nommage!
Posted : 20/08/2012 8:29 pm
See - that there exposes a lie. I once posted a thread saying how much I'd enjoyed a big dirty sirloin steak that i'd had. Your response included all of the things I mentioned above.
tut tut tut.
Posted : 20/08/2012 8:31 pm
Only turn once, cook the fat first then the presentation side, then turn.
pan very hot and dry, steak oiled.
rest on a warm plate for the same amount of time as cooking.
learn the done-ness test; place your first finger gently against the tip of your thumb and press the pad at the bottom of your thumb - that's rare. repeat with the other fingers and feel it going up the scale.
Don't be told how to HAVE your steak; but considered opinion does SUGGEST the best for flavour. for sir loin I like the contrasts of char outside through to rare within.
Posted : 20/08/2012 8:36 pm
I'm a firm believer in one flip.
You've just got to be confident, get the timing right, and commit. Flip too early and you risk multiple flips resulting in a dried out old leather boot piece of meat.
Definitely no salting until after its cooked or you'll draw the moisture out of the steak again resulting in leather boot syndrome.
Posted : 20/08/2012 8:48 pm
Robinson's are good but he is very expensive these days, I remember when he was no more expensive than the other local butchers and he still uses the same wholesaler as some of them.
Raymond Blanc's mums recipe is the simplest and is essentially what most are trying to do, plus deglazing to create a jus.
Posted : 20/08/2012 8:54 pm
steak out of fridge bring up to room temp lightly oil(extra virgin olive oil) salt and pepper bring good quality griddle pan up to VERY high temp cook steak to prefered state turn once only allow to rest serve with good chips and salad(rocket) 😀
p.s. good red wine is a plus point 😀 8)
Posted : 20/08/2012 9:37 pm
Yep, hot griddle... Sear fat side first then a minute or two per side.
Not normally a man to advocate steak + sauce / marinade, but some of my best efforts have sat in a bowl of teriyaki for an hour or two.
Only thing to beat the hot, hot griddle is a proper charcoal BBQ. Not briquettes or , heaven forbid, gas. Something about steak, lightly teased by glowing orange charcoal embers....
Posted : 20/08/2012 9:39 pm
Oh, and don't bother with that overrated Aberdeen Angus. Very little to compete with Welsh Black, for flavour and tenderness....
Posted : 20/08/2012 9:41 pm
That's the best way!
Really smoking hot pan, then a few minutes each side. Extreme heat is the key - the crispy black bits on the outside are just amazing, and if it's hot enough you can get this with the inside still soft and juicy... mmm..
A lid for the pan helps though otherwise you smoke out your house.
Posted : 20/08/2012 9:43 pm
Rkk speaketh sense re welsh black beef, best steak I ever had!
Posted : 20/08/2012 9:47 pm
Should not waste extra virgin olive oil on something you are going to cook, the impurities in it cause a lower smoking point.
Posted : 20/08/2012 9:49 pm
preheat the oven to about 180, get a dry frying pan really hot, oil the room temp steaks with an oil with a high smoke point - e.g. groundnut oil, don't use extra virgin olive oil, season with a bit of salt and pepper just before putting in the pan, sear it on one side then flip, chuck in a bit of butter then put straight in the oven for a couple of minutes. done.
Posted : 20/08/2012 9:51 pm
I sometimes do mine in the wood burner .
when the wood has gone down to glowing embers steak in one of those mesh fish bbq holders and into the stove couple of mins and its done to my liking pretty intense heat in there crisps up the fat too .
Agree with many posts here already.
EDIT - I like my steak rare or even blue - if you want to (subjectively) ruin yours by cooking for longer use a less hot pan or finish in the oven as mentioned below.
Bring steak up to room temperature before cooking.
I personally trim off any 'edge' fat before cooking.
Searing hot pan (I use a cast iron skillet rather than a griddle pan).
Oil (with a flavourless oil), salt and pepper on steak just before cooking.
Into the pan for 2 or 3 minutes depending on thickness of steak (nothing worse than a steak that is cold in the middle).
Flip once and cook for slightly less time on the other side.
Rest for at least as long as you cooked it for.
Lightly season again and serve with wedges, salad and fried mushrooms.
If you're not making a sauce, pour any resting juices over the steak once served.
Only thing I take issue with is the choice of Sirloin. Rib-eye every time for me.
slainte 😀 rob
Posted : 20/08/2012 9:54 pm
Why the insistence on such a hot pan . Great if you want it blue but if you want it medium or more then it will be charcoal on the outside before it is cooked on the inside .
Posted : 20/08/2012 9:55 pm
good caramelisation with hot pan, then oven cook once sealed to cook through at a more even temp to your preference.
Posted : 20/08/2012 9:58 pm
 grum
Because you don't want it medium or more. How very dare you!
Posted : 20/08/2012 10:01 pm
As has probably been said, steaks at room temp.
Then season steak, lightly oil , then into a smoking pan.
3 mins then flip , then 3 , remove and rest for 7 mins.
Works for me
Posted : 20/08/2012 10:02 pm
Need. To. Eat. Steak.
Posted : 20/08/2012 10:06 pm
How can you even think of putting that in a frying pan?
Barbeque is the only way to cook it.
Take it out the fridge when you get home and chuck some Olive oil and Worcester sauce in a bowl, mix it up, chuck the steak in and cover it.
Go outside get your fire going, briquettes are the easiest to control the heat. A chimney fire lighter from Weber rocks. Wont take any longer than 20 mins to get a nice hot base of coals. As the flames die and you have a nice glow. Use the heat from the coals to clean the grid.
Fetch your steak from indoors and place in a plate put some salt over the meat just before you put it on the fire salted side down and sear.
Put some salt on the raw side and don't touch it! After 2 or 3 minutes turn it over and sear the other side. Move away from the direct heat and put the lid on your Barbie for a a few minutes. Turn it over if you have to otherwise put it on a plate and eat it with a nice glass of red wine!
If thats all too much for you bring it by my house and I will cook it for you just how you like it.
You will never eat another steak in a restaurant again.
Cos it's the best way of cooking steak. Would it help if I called it sauteing?
You eat in the wrong restaurants.
Posted : 20/08/2012 10:08 pm
 jruk
If you want something different season with freshly ground black pepper, leave it to come to room temp, sear for 60 secs each side, rest for 15 mins, slice thinly and drizzle with a little of the best balsamic vinegar and olive oil you can get hold of. A little parmesan maybe.
Alternatively just eat the bugger raw with a decent Malbec. Bloody lovely.
Posted : 20/08/2012 10:12 pm
Hopeless! All of you!!! 🙄
What happened to the glass of red wine that you drink before you cook it???
SB
Posted : 20/08/2012 10:16 pm
