Blimey how does that work? What are the bushings made of that they absorb the GT? The spray stuff is Teflon in solvent isn't it?
I shouldn't have stated it as a fact above, I have no source other than my own experience.
I'm not going to lie and say I know why, but I am 99% certain it is what fecked my forks.
I'd assume it was a solvent other than the Teflon as I've had no issues with other teflon based lubes on my forks.
What happened is that I opened them up and they were fine if a little dirty. I didn't have any IPA to hand so I instead sprayed GT85 on a cloth then used this to degrease and clean the seals, I wiped it off and upon reassembly they were immediately very tight and had loads of stiction. Felt a bit like an old ZZYXY fork if anyone remembers those 🙂
After an embarrassing trip to the LBS to admit my error and have the bushings replaced the forks were good as gold again. (the seals were not changed)
I suppose if the seals are in perfect nick, the GT85 shouldn't get inside anyway, but i'm not taking the chance
