Seatpost stuck in B...
[Closed] Seatpost stuck in Blue Pig
Could you leave the bike in a warm room and over time let the steel expand and catch up the alloy and pour cold water over the post?
Would a blow torch to gently warm the frame damage the bike material?
Posted : 15/02/2010 5:38 pm
I can't believe I'm about to defend Hora, but any 'doubters' should look at impact drivers, they work the same way.
Posted : 15/02/2010 5:42 pm
We had on like this once, the alloy had a grove cut into it by a burr inside the post, be careful by the time ours came out there was a bit of 'ovalisation' at the top! If this is the case with yours just see it it will pull up in one position better than others, and means that small movement twist, one way than the other, whilst pulling, might be better than continuously twisting one way whilst pulling. Good luck, let us know the result
Posted : 15/02/2010 5:43 pm
Impact drivers are there to release bonded fasteners, not ones that are loose enough to rotate but are catching on something and not sliding out fully. Same applies to seatposts 🙂
Posted : 15/02/2010 5:48 pm
So we are assuming that 'something' is caught in the frame?
I thought modern manufacturers would of sorted that kind of problem, maybe not 😉
But I cant see how if the post has gone down the seat tube, it cant get back out, if you suggesting a bur then surely that would of been pushed further down the seattube when the post was inserted?
If its a case of the post was forced in then I take it all back, hard in will of course equal hard out, but more so.
Posted : 15/02/2010 5:57 pm
Bilt Hambers Farrosol release oil
http://www.bilthamber.com/ferrosol.html
Posted : 15/02/2010 6:19 pm
That's pi$$ poor, the frame's haven't been out for long. I bet you didn't get that problem with your Thorn James?
Posted : 15/02/2010 6:22 pm
Can we have a diagnosis and repair rather than a witch hunt?
Posted : 15/02/2010 6:26 pm
Use window cleaner - ammonia dissolves aluminium oxide.
This really does work - spray a bit twist, spray twist, maybe spray some wd40 to lube it up too (but it'll need continuous applications of ammonia)
Posted : 15/02/2010 7:07 pm
This is what you need, its a slide puller or hammer, drill through the seat post and attatch bar, and then use the hammer to shock the post out. This set has internal and external jaws for gripping bearings etc so they may grip the post. The post turns so it isn't seized it sounds like its stuck on a lip or ridge. You can also hire these from tool centres.
http://www.machinemart.co.uk/shop/product/details/cht251-10-pce-slide-hammer-puller-set
These will pull a hub of a car they should pull the post out of the seat tube!
Posted : 15/02/2010 7:19 pm
Try the non-destructive way first!
Posted : 15/02/2010 8:06 pm
variation on inbred's suggestion. Had a similar situation on a kids Hotrock. The post would turn but not come out. We tapped a thread on the inside of the post, screwed in a slide hammer with a bolt welded onto the end, a couple of blows an out it came. There were some serious grooves on the post when it came out - must have been some debris on the welds that locked the seatpost in.
Posted : 15/02/2010 8:47 pm
 hora
The ONLY time my method hasnt worked has been a carbon post in a steel frame as the bond is probably tighter but more importantly....the carbon tends to 'absorb' the shock waves rather than transmit the 'shock' to the sticking-surface.
Posted : 15/02/2010 9:43 pm
I feel sorry for the pig , no wonder its blue
Posted : 15/02/2010 10:06 pm
Now, if you Waxoyl'd it from new..........[opens a can of worms for the nay sayers to dine on]
Well, did ya get it out?
Posted : 16/02/2010 12:44 pm
 hora
There is only one way to settle this....
FIGHT!
Posted : 16/02/2010 1:13 pm
use or make a slide hammer
Posted : 16/02/2010 3:10 pm
Not yet but I've been away - will have a good go at it next weekend
Posted : 21/02/2010 7:31 pm
It's now been at 18 Bikes for 2 weeks - hopefully they can get it out without damaging the frame
Posted : 13/03/2010 4:50 pm
Plusgas.............loads
If all else fails....cut the post across the top....then cut sections down the inside of the post until you can fold a section out........then the rest will follow
Posted : 13/03/2010 10:55 pm
Bang it into the frame - it worked on stumpjumper which hadn't been touched for over a year.
We had tried everything -plusgas, kettle trick, hole drilled & connected to a 10ft scaffolding pole to twist etc. All didn't work.
I was actually selling the bike & the guy was literally 10 mins away - final option was the hammer into frame trick - 30 seconds later - new post in frame & as good as new.
Posted : 13/03/2010 11:17 pm
Any news James?
Posted : 29/03/2010 6:16 pm
Yes! Had to get a new frame under warranty. There was a burr of metal down the seat tube stopping the post from coming out but allowing it to twist.
Great service from 18 Bikes/Ragley/Hotlines who supplied new frame, post and saddle and swapped all the bits over.
Posted : 29/03/2010 7:02 pm
I love a happy ending, it makes me want to cry 😥
All's well that ends well, good to see the warranty works on these new breeds of pig iron 😉
Posted : 29/03/2010 8:52 pm
Page 2 / 2
