RP23 - Propedal not...
[Closed] RP23 - Propedal not "working"
[#7012163]
So I've just built up an old Five frame. Drunken ebay bargain, it came with an Adaptive Logic RP23 shock. The bikes ride brilliantly, rear suspension is super-plush, partially down to the Kashima coating I presume. Running approx 25% sag at about 220PSi (I way about 80kg + kit) and the shock doesn't appear to be losing air.
Problem is that no matter what pro-pedal setting its on, it seems to bob under pedalling.
Whats happening? I know its not the same as a lockout, but it would be nice not to pogo my way up road-climbs.
Posted : 21/04/2015 12:21 pm
What else did you expect from an orange five?
Did the fanboys get to you?
Posted : 21/04/2015 12:33 pm
Mine is the same. Had it fixed once and it's gone again.
Seems a common occurrence.
Posted : 21/04/2015 12:36 pm
If the shock has a boost valve then the boost valve has failed and needs repairing. Mine did the same and I understand its a very common fault. THe shock needs to goto the service / repairer of your choice.
Posted : 21/04/2015 1:01 pm
my 2012 one was exactly the same. apparently it's poor internals design and a diaphragm which ruptures easily. sent my off to TF tuned to get it push tuned when i last had it serviced and they replaced the internals with shims and now makes the world of difference. only £25 iirc on top of normal service charge so well worth doing
Posted : 21/04/2015 1:07 pm
The Boost Valve went on my old RP23, I got TF to Push it as it was hardly anymore expensive than the standard service. Much better in my opinion. Although I never bothered using the ProPredal on my Alpine 160. Managed to get a CCDB coil for free last year though and never looked back.
To be honest I''be never had a problem with pedal bob on Orange Bikes and never got on with Pro Pedal (and other Brand's versions).
Posted : 21/04/2015 1:21 pm
Must be very personal, when I demo'd an alpine the orange rep made sure the propedal was set to the max, and it still bobbed.
Posted : 21/04/2015 1:23 pm
Right, I'll go and see if Gravitate Cycles can sort it out...
Posted : 24/04/2015 9:55 am
So the Push Tune gets rid of the dodgy internals ?
How firm is the "lock out" afterwards?
Posted : 24/04/2015 4:46 pm
