1) Yes. I pedal extremely smoothly (150+rpm with no bouncing, near enough 200 max, 30+ years of practice on the track and road, helps). The galaxia STILL rocks backwards and forwards about 1cm. On a normal roller i can see (on video footage) the bike rocking back and forth a small amount, you can’t actually feel it either way, but i suspect some one with a choppy pedalling style might have issues at higher cadences. Friends have actually maxed out the movement on the galaxia. Flat out, out of the saddle sprinting is possible, but not advised unless you have room to fall off 😉
2) Rollers aren’t as bad as turbos on your tyres as you move around a lot more. You don’t get the “hot stripe” down the middle of the tyre.
I still use a roller tyre as a) i had one and b) it’s quieter than normal tyre. I use a knackered old almost bald tyre on the front.
I only paid about €110 for the galaxia thanks to a pricing error. I was going to get the basic model (that was €10 more expensive!) glad i didn’t. In hindsight, i should have budgeted for the galaxia anyway.
