- This topic has 73 replies, 38 voices, and was last updated 6 years ago by mrblobby.
Road tubeless love/HATE
flangeFree Member
Hate camp for me. Ran hunts with Pro ones in 28mm, even with Hunt setting them up for me they kept leaking. Then the rim tape let go and I had to bung a tube in. Have tried numerous times since then to get them up and running tubeless and gave up.
Also not a fan of Pro ones. Wet weather grip is terrible (compared to GP4000s) and I find them a bit ‘wooden’, feel wise.
I’ll stick with tubes. Get a puncture on a tube, you just bang a new tube in and you’re off again. Similar on a tubeless setup and you’re stood at Lewisham roundabout breaking your thumbs trying to get the tubeless value out whilst wondering why you bother….
reggiegasketFree MemberFan here. Had a Pro One split on the sidewall when I clipped a rock, which couldn’t be mended.
Otherwise all good. The Pro Ones are definitely more delicate than the older Ones, but they are lighter so you can’t really have everything.
Many problems can be traced back to poor initial setup and sealing – not all but most. Once you get these sorted they are usually fine.
For me, road tubeless offers the most value in commuting. My G-One Allrounds have taken a heap of abuse on and offroad and have ‘punctured’ loads of times but have still got me to work, albeit on a soft tyre.
TiRedFull MemberWhat is this rim tape nonsense? Just run tubeless on ksyriums and be done with it.
The only issue I have with road tubeless, is that a serious puncture pretty much renders the tyre no longer useful as it won’t hold high enough pressure, despite sealing.
But the ride of those Corsa Speeds has to be felt to be believed. Raced them again on Wednesday and the combination of non-tubeless Hed Jet 6/9 is just wonderful. Fastest wheels I’ve ever ridden. Perhaps not for road racing though (too many triathlete comments ;-))
epicsteveFree MemberI’ve got tubeless ready wheels and tyres but haven’t been tempted to try tubeless on the road bike as it does seem to be a solution without a problem for me, as I (touches wood) find punctures on the road bike pretty rare – I’ve done 3000km this year so far without one.
On the commuter I’ve taken the alternative approach and used Schwalbe Marathon Pluses (with tubes) and haven’t had a puncture with those in God knows how many miles.
brakesFree MemberI’ve done 1,000 miles on Schwalbe G-One 30s on Pacenti Forza rims. No problems so far. The rear has a very slow leak, I think it’s around the valve as the hole I put in the rim tape was too big.
Getting them to seal takes a bit of effort, but then I’m just using a normal tack pump. I love the snap sound of the bead seating.reggiegasketFree MemberOn the commuter I’ve taken the alternative approach and used Schwalbe Marathon Pluses (with tubes) and haven’t had a puncture with those in God knows how many miles.
That’s fine but they weigh a tonne.
njee20Free MemberDone a few rides on mine now, rear was inexplicably flat last week when I went to ride home. Pumped it up, had to top it up on the way home. Held air pretty well since, pumped it up last night for this morning’s commute and it was flat as a pancake this morning. Pumped it up again, air pissing out everywhere, would guess the tape’s torn as no obvious leaks. It was 6am, so I grabbed another wheel and will check it later.
Not overly impressed. Definitely edging back towards tubes.
joemmoFree Memberjust taken delivery of some 35c panaracer Gravel Kings to run TL for general mixed surface commuting and riding so am preparing for love / hate / indifference. Rims are archetypes with Stan’s tape, but I might try rim strips as well if it proves problematic
reggiegasketFree Memberwould guess the tape’s torn as no obvious leaks…. Not overly impressed. Definitely edging back towards tubes.
As I said earlier… many problems can be traced back to poor initial setup and sealing. This is not, per se, a shortcoming of tubeless. Rather you need to set it up well initially, which does take some experience. I’ve made mistakes with it in the past but there are tips and tricks which help.
beejFull MemberMixed here.
2 sets of Easton tubeless ready wheels – sealed rim beds, no tape needed.
Very easy to set up with Schwalbe Ones/Pro Ones. Tyres went on with just thumbs, inflated with a track pump.One set of Prime RP38s, with rim tape. Bitch of a job getting them on – couldn’t get the tyre on the rim, then took a layer of tape off, got tyre on but had problems sealing, then tape blew. Eventually stretched the tyre a little with a tube in, managed to get them on and sealed. Stay up very well now.
Had two non-sealing punctures, both probably because I’d not topped the sealant up. I carry the genuine innovations road tubeless plugs now.
Overall, veering to the positive but tyre/rim does make a big difference to the usability.
njee20Free MemberAs I said earlier… many problems can be traced back to poor initial setup and sealing. This is not, per se, a shortcoming of tubeless. Rather you need to set it up well initially, which does take some experience. I’ve made mistakes with it in the past but there are tips and tricks which help.
I’ve been using tubeless for 16 years on the MTB now, and have set up about 30 sets of wheels over the years, it’s quite likely that set up was to blame (not least as I used sub-optimal tape), but that’s still a bit shit. Would have been fine with a tube.
Initial set up was fine too, the first 250 miles or so have also been absolutely fine on the rear, for it to suddenly dump all the air out in response to nothing more than being inflated (and not even ridden), I’m not overly impressed.
mrblobbyFree MemberAlso not a fan of Pro ones. Wet weather grip is terrible (compared to GP4000s) and I find them a bit ‘wooden’, feel wise.
This too.
njee20Free MemberYeah I wasn’t that keen on Ones (actually found Pro Ones better), never actually had an issue with cornering grip, but I find them a bit ‘skippy’ when climbing if it’s damp, which is enough to discourage too many heroics whilst descending.
mrblobbyFree MemberThis thread isn’t filling me with much confidence either…
http://singletrackworld.com/forum/topic/repairing-road-tubeless-tyres
munksterFree MemberLove love love… It isn’t for the feint hearted, it isn’t without its learning curve, but once tyres are on the feeling of liberation is pretty palpable. No more pinch flats and any piercing punctures are sealed up with the minimum of fuss (although the initial “please seal please seal” few rotations is never nice IME). I never carry a tube and have only had one ride-ending “event” that would’ve killed any tyre tubed or not. All the others just sealed and I rode on with no pressure loss.
It seems there are as many experiences as there are users however. I’ve had a tyre and rim combos ranging from “this is never going to happen” to “on with thumbs” and that’s very easy to forget for those who seem to swear blind that someone’s got bad technique when it’s harder than it’s meant to be. If you are unlucky to have one of those ultra-frustratingly tight combos first time out you may well end up being put off for ever which is a real shame. Equally some people seem to get multiple non-sealing punctures which is also going to put you off.
I’ve rarely recommended road tubeless to riding buddies for the above reasons, just in case they have a nightmare with it. But as long as you go into it with eyes open and accept it can be frustrating, then it’s worth it…
mrblobbyFree MemberNo more pinch flats and any piercing punctures are sealed up with the minimum of fuss
Every failure I can recall on the road bikes (at least since going to latex tubes) have been flint cuts. Never get pinch flats of pin hole like punctures. For me it’s a PITA solution to a problem that I don’t have. Tyre unseating on a ride is probably the nail in the coffin.
munksterFree MemberTyre unseating on a ride is probably the nail in the coffin.
Does that happen then? Honest Q, never happened to me in 20,000+ km!
Pierce/cuts, same sort of thing to me really, I’m not suggesting all of the punctures I’ve had have been down to perfectly oriented thorns or whatever…
Edit: anyway I’m not trying to convince anyone here, stick to whatever you’re happy with! I know I am 😉
ackieFree MemberI’ve had a couple of big flint cuts that have meant the sealant won’t seal the hole. Annoyingly on a tyre that was only a couple of rides old!
I have resorted to patching them up internally with a standard inner tube patch.
Fingers crossed it will hold sealant now and won’t affect the ride as there is a definite lump in that area now.mrblobbyFree MemberDoes that happen then? Honest Q, never happened to me in 20,000+ km!
Did for me.
Hate today too. Wanted to fit in a quick ride. Tyre flat. Pumped up, bit of air seeping from the rim. At least it seemed to be seated. A couple of spins and it was holding air again but really zero confidence that it’s going to be ok for duration of ride. Going back to tubes.
munksterFree MemberBlimey mrblobby you have had a crap run of it!
I do wonder what the ratio of good to bad experiences is. Aside from the pain (sometimes literally) of getting the tyres ONTO the rim in the first place at times, I have had a gold-plated positive experience with road tubeless. I am beginning to wonder if I am the exception rather than the rule!
TiRedFull MemberChopped two Corsa Speeds: one was over a lot of glass, so needed a tube. The second was a sidewall cut that sealed eventually in a TT. Ride is fantastic, I have confidence in them despite non tubeless rims.
We shall see if they repay that confidence in a 90 mile road race on Sunday (French roads).
fibreFree MemberLovvvve!. 30mm S-Ones\Stans Grails\Stans Tape\Orange Seal. 3500+ miles with no flats, no way i’m going back to tubes!.
Went up first time with a track pump, I once had to dump some pressure in when I cut the sidewall on a rock but it sealed up fine. It’s great being able to ride all surfaces on the same bike, road, gravel and bridleways without the tyres letting the ride down. They’re fast on the road but more comfortable than the 35mm tubed cross tyres I had for offroad.
alanw2007Full MemberHate/given up stage for me. Proper tubeless with Dura Ace wheels and IRC tyres was ok; tyres would inflate reasonably well with a track pump and rolled nicely.
But converted rims with Hutchinson or IRC tyres were an awesome pain in the arse. Thumb-breakingly tight to mount and then needed a compressor to seat the beads. And a poor record of sealing tyre cuts at high pressure. Maybe worked one time in 10 but usually the Stans would just shoot out of the hole.
I just can’t be bothered with it any more. Maybe newer stuff is better.onandonFree MemberMy opinion of road tubeless is that it works really well on larger tyres. 30s and upwards but smaller road rubber doesn’t reseal.
Really happy with schwalbe s-ones in 30. Pro ones in 25 were shite.
So. Back to latex tubes for anything under 28 and tumble less for anything over.
llatsniFree MemberCommuter and road bike both tubeless “road”. S-ones on the commuter have been the best value tyres I’ve ever owned! Pro-ones on the race bike the fastest.
6000km between them since I started tracking things and not a single puncture. There has been one or two nearly-punctures but the sealant did its job. They do require regular air top ups, but you should be checking your pressures even with tubes.
Lower pressures, more comfort, more grip, faster speed, as light if not lighter… don’t understand why it’s even a debate any more.
speedstarFull MemberBeen running tubeless on both road and mtb for last 2 years. Never going back to tubes as in that time I have had 1 puncture in total! The downside, and it’s one I experience with mtb wheels much more than road wheels, is the tolerances between rim and tyre are extremely variable. Each combination of tyre and rim demands its own solution to getting to them to inflate easily and stay inflated. I have used 5 (!) layers of rim tape on my superstar wheels to get my HDR2 to stay up although I bought them in the sale as slightly NQP…
With road tyres, I would say if the tyre doesn’t start inflating relatively easily then you are likely to have problems soon in terms of leakage. Worth taking the time at initial setup to get the tyres to a point where they will re-inflate with a normal track pump. And using TLR wheels is essential tbh IMO.
YMMV..
cookeaaFull MemberStill not tried tubeless on the road but this thread is interesting. I love the idea and while it seems like there’s been some progress made with the details, there’s still too few users finding road tubeless as reliable as MTB tubeless (from this collection of anecdotes anyway)…
When it works is the ride worth the faff yet?And also this:
I suppose string type plugs are a no go as you’ll end up with a bloody great lump to shave/wear down? Are internal patches not a possibility? Some variation on Mushroom type plugs? There must be a way to do it…
But if a tyre really is a total write off after after one significant cut (~6mm-ish?) that’s hardly a selling point…
The general repairability of current MTB tubeless tyres (both on the trails or once back at home) is one of their major attractions now…
DezBFree MemberLove! Hated fitting a Pro-One, the other one was fine! Been tubeless for 2 years+ with ONE single puncture – which sealed in about a minute. And for that reason I ain’t going back. Those days of sitting by the side of the road with filthy hands and an upside down bike, getting home half an hour late and missing Pointless, are gone!
Thing is though, do what you want, doesn’t matter to me. 🙂mrblobbyFree MemberLower pressures, more comfort, more grip, faster speed, as light if not lighter… don’t understand why it’s even a debate any more.
I think that’s all true if you are running fatter tyres. If you are at 25mm then I think it’s debatable. Rolling resistance is no better than the better open tubular with latex tubes. Weight is the same. Feel, IMO is better with tubes, probably as the tubeless tyre is more rigid. I run fairly low pressures with latex tubes. And I hardly ever suffer from punctures that wouldn’t trash a tubeless tyre. And in narrower sizes tubeless becomes an increasingly big PITA to fit due to tightness (and mine have unseated mid-ride).
So this…
TiRedFull MemberI think Mr B is right here, the very best clinchers with lightest latex tubes are almost as good as the best tubeless road tyres, a lot easier to fit and generally, a little less pfaff. But when chasing that last few watts those Corsa Speeds are as fast as duck. Fabulous on the French roads, too fragile for the UK. Race day specials only. I’ll race them again at Hillingdon tomorrow.
For bigger robust tyres, tubeless road offers pretty much the same benefits as off road. My 30c G-One Speed tyres are superb fast tyres run at about 70psi.
mrblobbyFree MemberBut when chasing that last few watts those Corsa Speeds are as fast as duck.
Very little in it, maybe a watt or two either way at most. Looking at the bikerollingresistance tests there’s about than 3 watts between the Corsa Speed and a Turbo Cotton, but the Turbo Cotton was tested with a butyl tube which seems to add a couple of watts over a latex tube.
mrblobbyFree MemberHaving found a tubeless road tyre that would fit my rims I had a brief honeymoon period of about a week. Today’s ride, wet, cold and dark, picked up a puncture. Got a quite spectacular fountain of orange seal that lasted until the tyre was flat. Couldn’t get it to seal. Wasted a CO2. Had to put a tube in (which was both really messy and had other problems). Not quite hate yet but seriously unimpressed.
mrblobbyFree MemberWell on closer inspection in daylight quite a big flint cut and maybe asking a bit much of sealant…
Have a tubeless repair kit somewhere, shall dig it out and see if it could have been fixed roadside.
Has made me think about how to fix problems like this. Usually just carry a spare tube, a CO2 and a micro combo pump inflator thing. Could easily waste a CO2 trying to see if a hole will seal, and micro pump isn’t anywhere near potent enough to get a tubeless tyre to seat. Think putting a tube in and not messing with repair kits and trying to get the hole to seal is probably the most efficient way to deal with it.
The topic ‘Road tubeless love/HATE’ is closed to new replies.
