To answer the OP’s question: it’s got a paddle behind the brake lever, which makes it Sora 3500 rather than 3400 (see https://en.wikipedia.org/wiki/Shimano#Road_groupsets).
According to this it’s max sprocket size of 32, and total capacity of 37.
So you’re OK on sprocket size. 11-32 is using up 21 of the total capacity, so you’ve got 16 to play with at the front. In other words, as long as the difference in size between your front chainrings is 16 or less, you’re good to go. A typical compact is 50/34, which would be 16. That’s fine, but right on the upper limit, so important you get the chain length right.
