Revs can the travel...
[Closed] Revs can the travel be shortened ?
[#4548654]
Still trying to find a 120mm, tapered, thru axle fork for for a 29er. CRC have these [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=85096 ]29er 140mm Revelations[/url] Can the travel on these be reduced to 120mm ?
Thanks in advance, D.
Posted : 12/11/2012 12:44 am
 nuke
Coincidentally Alan has a similar query tonight...yes seems to be the answer but it's not as straight forward as it use to be where you popped an all-travel spacer in. See here...
http://singletrackworld.com/forum/topic/2013-rockshox-spring-internal-change#post-4362693
Posted : 12/11/2012 12:53 am
Looks like I'm sorted with a fork 😀 Spoke to TF Tuned who can supply a shortened travel, Taper steerer, Rock Shox Revelation RCT3 Solo Air - 29"
Excellent "can do" service over the phone from TF. Thank you 😀
Dave.
Posted : 12/11/2012 12:11 pm
