I’m running a 10speed XT Cassette on a n 11 Speed compatible hub. A spacer ring came with the hub for use with 10 Sp cassettes and that’s fitted, so the cassette is in place and fits fine.
The problem is, I’m running 29+ tyres and if I select my bottom gear, the chain is rubbing off the tyre and I can’t use it. Is there a way I can step the cassette out further using a spacer? I would be happy to forego the 11 or 13 tooth sprocket and just run it as 9 gears just to get access to the biggest sprocket on the cassette.
Is this possible?
Assuming so, is it possible to ditch the 11t cog, or is that needed for the lock ring and the only option would be lose the 13t?
Can you buy such a spacer? I know there’s a range of spacer sizes in a ss hub converter set, but I’m not sure if any of these would be the right size and I cannot find a single sprocket spacer.
Any help gratefully received!
