Removing paint from...
[Closed] Removing paint from Ti frame.
[#4710323]
I want to remove the painted wording on a new frame. Got the usual Google qualifications sorted and there seems to be the opinion that certain chemicals can be unkind to titanium.
Anyone sucessfully removed paint with, say, Nitromors ? Will I need to wipe down the frame with something to stop any 'eating' process continuing...?
Tell me what you know/personal experiences, please...
Posted : 03/01/2013 9:34 pm
Brillo pad/Steel wool?
And finish off with some Duraglit.
Posted : 03/01/2013 9:37 pm
 LeeW
Scotchbrite
Posted : 03/01/2013 9:38 pm
The frame's a polished finish - any problem retaining that using the steel wool technique...?
Posted : 03/01/2013 9:39 pm
Titanium is a very hard metal so paint stripper will be fine on it. I expect whatever you use will require a bit of repolishing to bring back the full shine
Posted : 03/01/2013 9:49 pm
I used Nitromors to strip the lacquer off my original Tinbred and then rinsed it loads and polished it up with a light grade of sandpaper.
That was 5 years ago and I'm still riding it with no issues 🙂
Posted : 03/01/2013 10:18 pm
Excellent. Nitromors it is, then.
Just Googled Duraglit as I've never heard of it. Just the job for polishing metal.
Thanks, folks.
Posted : 04/01/2013 10:44 am
water neutralises nitromors so when you wash it off you should stop any reacting.
Posted : 04/01/2013 11:43 am
"...there seems to be the opinion that certain chemicals can be unkind to titanium"
http://www.sciencedirect.com/science/article/pii/0010938X73900371
First choice would be to try [b]acetone[/b].
DOT 4 or 5.1 brake fluid is a good paint-stripper.
Posted : 04/01/2013 1:06 pm
Thanks for that little gem of info, Macavity. A quick skim read suggests issues from alcohol and Nitromors contains methanol. Some of the info regarding dot brake fluid suggests it also contains [something]thanol that I'd have to study further to know WTF it actually is.
Think I'll play safe and drop into a chemist for some acetone.
Once again - ta.
Posted : 04/01/2013 8:03 pm
