Just finished building a new bike and fitted a brand new Reba RLT (2012). It’s a Poploc version so using a Poploc Adjust.
Took it out for the first time on Saturday and messed about with positive and negative air and low and high speed compression (using the gold threshold knob) and was happy after 20 miles or so.
Went to check the positions I’d settled on for low speed and threshold adjustments last night so I could make a note and as I turned the threshold knob, it got progressively stiffer whichever way I turned it and now can’t be turned – if I try now, it turns the blue low speed compression with it against the spring/cable and no matter how hard I turn the threshold adjuster in either direction, it just won’t budge.
I don’t *think* that I’ve backed the threshold adjuster against it’s stop and it’s stuck there. Anyone got any ideas?
Thanks in advance.
Stu
