Avast ye.
today, at long long last, the shed has gone up (at my rented place) and so by tommorow morn, i will be able to fill the 8×12 box with my toys 🙂 just in time for the on ones to be shipped early next week too, all going well.
however, its now dark after 5:00, so i wont be able to build said on one, without some illuination.
the set up is this
1). there is an exterior socket on the end of the house.
2). its about 15m to the shed.
the obvious answer is:
run a 15m extension lead, from the shed, to the house, wire it so it can be passed out the shed, across the patio to the socket, when needed, and wound away when not needed so its not in the way/getting wet.
then fit a 150w work light or an inspection lamp inside, and hang it up from the roof.
i think an RCD on the plug would be a good plan too.
however i open it to the panel for any suggestions or modifications to this…
solar power would be nice, but is there a solar availible lamp that would kick out enough light to comfortably work by?
