- This topic has 120 replies, 46 voices, and was last updated 9 years ago by molgrips.
Power loss on full sus' bikes compared to hardtail's
markrhFree Member
Is their a comparative approximate industry figure of power loss? It crossed my mind the other day when comparing times on my regular riding circuit over Cannock chase. Both bikes I use weigh in at around 28lbs and roll on the similar tyres and have similar riding positions but the hardtail is always without fail the quicker bike by five minutes plus over 11/2 hour ride.
I know this is a more complex than i’m presenting it as some full sus’ bikes suspension systems are more efficient than others and the type of terrain has an impact but would be interested to know if there is a figure..JCLFree MemberLook at the results of the XCO World Champs. Only one hardtail in the top 10.
mjsmkeFull MemberWasn’t a full sus in the top 3 of the olympics xc race? Might have been 650b too.
notmyrealnameFree MemberWasn’t a full sus in the top 3 of the olympics xc race? Might have been 650b too.
Kulhavy won it on a Specialized Epic 29er full sus.
akakFree MemberBut the xc bikes will have a lockout so they aren’t losing any power, just carrying more weight.
tonFull Memberfat blokes lose power on full sus.
dont think there is a full susser really suitable for fat blokes.molgripsFree MemberAny power you would lose would have to end up as heat in the shock. Does your shock get warm when you ride XC? No.
I don’t think you would lose speed anyway. If you ride rigid the rough stuff slows you down more than any theoretical energy loss. On a FS some of your forward momentum ends up in the shock; on a HT some of your forward momentum gets converted into up and down momentum instead.
JCLFree MemberWhat Molgrips said plus the extra climbing traction, cornering traction and lower fatigue.
In short, hardtails are shite.
rollindoughnutFree MemberUseless to compare an xco bike to a normal susser. They are using things like electronic lockouts now which is why full suss has become an option again. When climbing you can see there’s no bob at all.
On a normal bike I can’t see how the saddle bobbing up and down as you peddle can be anything but bad.
slackaliceFree MemberDo you suppose in a another 20 years, someone will pose the wheel size question?
bolFull MemberI’d say full suss bikes (unless they lock out) feel slower up most hills than a hardtail. Much less direct when you stand and pump. Similar when you sit and spin. They’re also generally heavier, which doesn’t help. Most people would probably make any time lost back up on the downs. I think Ton is right in that the weight of the rider is also a factor.
njee20Free MemberUseless to compare an xco bike to a normal susser. They are using things like electronic lockouts now which is why full suss has become an option again. When climbing you can see there’s no bob at all.
They’ve been pretty viable for about 10 years now. Some riders use them religiously (Kulhavy) some do so rarely if the course necessitates (Schurter, Absalon), some never do (Emily Batty). Personal preference. One isn’t better than the other.
Molgrips I’m intrigued you don’t think there’s any power loss? So if you outfitted a V10 with some 23c slicks, and hung some weights on a road bike they’d climb Alpe d’Huez the same? Can guarantee the shock won’t be getting warm!
molgripsFree MemberI don’t think there’s no power loss, I think it’s negligible.
Re the v10, I think riding position, wheels and tyres are most of the slowness.
njee20Free MemberHence you fit some 23c slicks in my hypothetical test. It’s a climb, so negligible aero gains, position needn’t be an issue. Frankly plenty of modern road bikes are just as upright anyway!
ampthillFull MemberI think like the wheel size thing you can answer the question for a rider on a course
But as the relative amounts of climobing and different surfaces change you get a different answer
I’m also unconvinced that comparing bike swith the same tyres is fair. It might be that the Fs lets you run a thinner tyre or a higher pressure for the same level of comfort or traction
If I was dumping 10W into my shock is that negligible? What it cause a noticeable heating effect?
yourguitarheroFree MemberOver a shorter course I don’t think there is much in it.
But after 3 or 4 hours of riding the full suspension is quicker because the rider isn’t so battered about.
njee20Free MemberAnd yet marathons (up to and including 24 solos) are won on hardtails.
There is no ‘better’ or ‘quicker’, it’s not that straight forward!
ndthorntonFree MemberI am so much faster on my hardtail – and it can’t be all down to weight. Although it is a good 9 lb lighter than my full suss, as a percentage of rider + bike weight the difference is bugger all.
On my local trails I always go for the easiest and smoothest ascents and the techy DH. So I don’t loose any traction on the climbs. If I have to ascent rocky climbs then the difference is much less maybe even quicker on the full suss.
So yes – depends what your riding.
mrblobbyFree MemberUse to be that you’d see the FS bikes ridden to please a sponsor and the shock would just be pumped up and locked out so that it was pretty much a HT. Think they are more prevalent now that the shocks are getting better, lockouts easier to use, and everything is getting lighter. Aren’t the WC XC courses getting more technical too (maybe why bars seem to be getting wider too.)
Also tend to see more of the men on FS bikes than the women. Maybe any efficiency loss is more significant for the women as a percentage of overall power, or maybe a weight thing or speed down the rocky stuff?
molgripsFree MemberAre you lot talking about pedalling bob, or thekinetic energy lost to the damper?
I think position has a lot more to do with it than aerodynamics.
ceepersFull Memberi think the terrain makes the biggest difference. From my own experience on my local climbs, there’s definately a correlation between roughness/ technicality and amount of suspension.
The two local 15 min fire road climbs im significantly quicker on my CX bike than either hardtail or full sus, the singletrack slightly rocky more technical route out of the village, my top few times are all on the full sus, i dont think i could clean it on the cx.
down or along, my anecdotal experience is that im quicker on the full sus, i stay off the brakes more and can keep the power down pedaling easier in the rough stuff on a full sus. once again, flat fireroad non rocky trails, the cx is quickest
jam-boFull Membergot it logged on strava? do a raceshape to see where you are losing time.
WozzaFree MemberIt’s probably been covered already, round Cannock that might be the case, but up here in Cumbria my hardtail was (with the exception of tarmac) slower and had poorer traction, up, along and down, than my 6″ AM full susser. Same rider, same trails, different bike.
I won’t be buying another hardtail.
nickjbFree Memberthe terrain makes the biggest difference
This. A full suss will be quicker and more efficient on the rough stuff a hardtail will be when it is smooth. For me gains of a full suss on the rough stuff far outweigh any gains that might be had on a hard tail for the smooth bits. If I just ride canal towpaths I might come to a different conclusion.
weeksyFull Membernjee20 – Member
I’ve done recent rides on 3 various bikes. All road based all on my ‘TT’ circuit which is 29km with some climbs/flats
My times are for a Carrera TDF(road rubber), Charge Cooker(commuting rubber), MetaAM29 (Ralphs)
There’s 3 mins difference between the 3 bikes overall. Interestingly I make up any gains on the flat section of the TDF, uphill I’m less than 2s difference between the 3 bikes. Downhill I’m quickest on the Cooker (confidence thing).
That’s for me….
boxelderFull MemberAny power you would lose would have to end up as heat in the shock. Does your shock get warm when you ride XC?
My mate’s squeeks and squeels like a stuck pig – that energy harnessed would make him awsumz
AlexSimonFull MemberAre you lot talking about pedalling bob, or thekinetic energy lost to the damper?
All and any power that doesn’t get transferred to forward motion I guess.
In which case, generating up/down motion in pedal bob is wasted energy.I think course designers in XC are under pressure to keep courses rough enough to prevent bikes from being too much like flat-barred CX bikes.
A higher UCI weight limit would mean more suspension too, if that’s what the marketeers decided was important.PJM1974Free MemberIs their a comparative approximate industry figure of power loss?
Yep, a full suss loses roughly 5-10 Glimbarts in comparison with a hardtail.
molgripsFree MemberI don’t think pedalling bob is an issue on XC FS bikes tbh.
This.
Also, on the more difficult climbs you have to be moving around on the bike more to keep the bike moving. This costs energy.
This also includes energy absorbed by the shock over bumps. The question is if this energy is preserved if you are on a ht.
AlexSimonFull MemberThis also includes energy absorbed by the shock over bumps. The question is if this energy is preserved if you are on a ht.
My thinking is that ideally the shock shouldn’t be absorbing anything other than vertical motion, so there’s nothing to preserve.
Except when there’s pedal bob (or honking bob). Then the shock absorber is working directly against you.
molgripsFree MemberThe shock does absorb forward motion, of course it does. If you coast along the flat on a bumpy trail, the shock moves and does work against the damper fluid – where’s that energy come from?
The swingarm might be moving vertically but only due to the forward motion of the bike and the leverage of the wheels against bumps.
roverpigFull MemberI’ve logged various rides on a number of hardtail (FF29 and Solaris) and full-suss bikes (Five, Trance and Gyro) over the past few years, including lots of attempts at the same segments different bikes. I’ve made a few attempts at trying to analyze these to see which bike is faster in various segments and I’d have to say that it is really hard to come up with any definitive conclusions. It does look as though the HT has an edge on smooth climbs (and roads) and the full-suss has an edge on rougher climbs, but the differences are much smaller than the day to day variation in my fitness/enthusiasm etc. So, I can find examples of smooth climbs where my fastest time was set on a full-suss (or rough ones where a HT wins), simply because I was feeling good that day.
Make of that what you will, but personally I’d say that, if you sit and spin up climbs (as I do), there is not much in it. The HT should win (if only because it is slightly lighter) up a road or smooth trail. The full-suss probably wins if it gets technical.
Racers do tend to stand on the climbs though.
zippykonaFull MemberI used to ride with a really quick bloke. Couldn’t keep up with him with both of us on rigid. I stood more chance with bounce. This was racing on really rough tracks.
So you may lose power but it’s quicker.AlexSimonFull MemberThe shock does absorb forward motion, of course it does. If you coast along the flat on a bumpy trail, the shock moves and does work against the damper fluid – where’s that energy come from?
The swingarm might be moving vertically but only due to the forward motion of the bike and the leverage of the wheels against bumps. See – I think it’s doing the opposite. It’s absorbing rearward motion. I.e the bumps are trying to force the bike up and rearward. The shock absorber is trying to absorb that energy to increase forward motion.
ndthorntonFree MemberFor me gains of a full suss on the rough stuff far outweigh any gains that might be had on a hard tail for the smooth bits. If I just ride canal towpaths I might come to a different conclusion.
Not for Winching and plummeting
If you ride smooth climbs, technical descents and no flat (which most people do where I live because of the geography) then the time you gain on the climbs far outweighs the time you loose on the descents simply because you you spend about 4/5 of your time going upwards.
The descents are no more or less fun on the HT, slower certainly but more challenging. I don’t prefer one over the other – its nice to have a change – but I can definitely get more in on the hard tail.
mattjgFree MemberWhat Molgrips said plus the extra climbing traction, cornering traction and lower fatigue.
Makes sense to me. I think in almost all cases a well set up and applicable FS will do a better job of covering the ground than a HT, especially loose or nadgery climbs when you want that rear wheel on the dirt not bouncing about..
False. Hardtails are great fun and I find I can’t be bothered with the maintenance overheads and endless technology churn of FS.
Covering ground as fast as possible isn’t the aim of MTB for me.
HTs for me.
PJM1974Free MemberThis thread has inspired me to take out my hardtail (which hasn’t been offroad since it was rebuilt in June) and ride back to back with my full suss. I feel a Strava coming on…
njee20Free MemberI don’t think pedalling bob is an issue on XC FS bikes tbh.
Then why aren’t they used by everyone in a competitive situation?
I’m quicker just about everywhere on my 29er hardtail than on my 26″ FS of the same weight.
The topic ‘Power loss on full sus' bikes compared to hardtail's’ is closed to new replies.
