plane and conveyor ...
[Closed] plane and conveyor belt
[#1662094]
Seen a few references to this recently and I can't remember what the definitive answer was, searched the forum with no luck.
So....will it or won't it?
Posted : 01/06/2010 12:09 pm
You need to ask?
Posted : 01/06/2010 12:10 pm
 Pook
no it won't. End of thread.
It will, apart from on Tuesdays.
Posted : 01/06/2010 12:11 pm
YES, for crying out loud, YES!
Posted : 01/06/2010 12:12 pm
Pook, why not?
Ian, the sex of the plane is not an issue.
It's been done, with a model aircraft. Yes, it does take off. You've gotta be a bit retarded to think otherwise too, being as a plane isn't driven by it's wheels..... 🙂
Posted : 01/06/2010 12:14 pm
Actually, the initial stipulations are hazy. Are the engines on but the conveyor belt is going in the opposite direction....someone fill me in.
no
Only if it has wings
Yes, the definitive answer is yes. Anyone who says no is WRONG!!
End of thread.
Posted : 01/06/2010 12:17 pm
That's the important factor!
Of course it would, it would need the conveyor belt to be the same length as the runway, it does not, as some seem to think, make it suddenly possible for planes to take off on the spot!
Posted : 01/06/2010 12:20 pm
It depends on how you conceptualise the conveyor belt.
Posted : 01/06/2010 12:23 pm
I can't find the original thread, but its a funny read!
[url= http://mythbustersresults.com/episode97 ]Plane & Conveyor Belt - Mythbusters, video included[/url]
Ah wings hit the treadmill...
wind speed over the wings = 0 as it is stationary (im assuming its stationary otherwise whats the point of the q?)
0 wing speed = 0 lift.
if it isnt stationary then yes. but then its not really on a converyor belt is it? its 1000m meters away having hurled off into the distance...
Posted : 01/06/2010 12:25 pm
The point is, with the engines running it doesn't make any difference... sod it. I can't be bothered.
Posted : 01/06/2010 12:28 pm
Yeah... and then you turn the engines on and it moves forward!
The conveyor belt can continue to move backwards at the same rate the plane moves forward, all that happens is the speed the wheels are travelling at is double the groundspeed of the plane.
Posted : 01/06/2010 12:29 pm
Am I missing an ironic in-joke?
Although groundspeed will be simulated by moving the wheels, this won't create any lift, as air won't be travelling over the wings.
Therefore it won't take off. Isn't it obvious?
Perhaps with a tiny model plane the surface of the conveyor belt will cause sufficient friction with the surrounding air to move a small body of air in close proximity, but this would be pretty limited.
Plane in a wind-tunnel would be a different matter.
Cheers, Rich
Mythbusters: http://mythbustersresults.com/episode97
Posted : 01/06/2010 12:30 pm
Put a model car on a treadmill and push if forward with your finger. Does it move forwards? Of course it does.
[url=
[/url]say YES!
Nurse, my pills...
Posted : 01/06/2010 12:31 pm
What if the conveyor belt is moving backwards (relative to the plane) at the plane's take-off speed?
Posted : 01/06/2010 12:37 pm
 LHS
Rich, yes you are missing something.
The planes wheels aren't driven!!!
The engines move the [b]AIR[/b]
It's a classic misdirection in the question.
What it should really say is "If you put a plane on a very powerful, very long, very wide treadmill and fired up the engines, then would the treadmill operator be able to prevent the plane taking off by running the treadmill in the opposite direction?"
To which the answer is most definitely, NO, they can't. The plane will be able to take off as normal.
This was about a real plane on a hypothetical 10000ft conveyor, not model planes and treadmills!
And of course it will, I don't get why people can't understand that!
Why would you simulate movement with the wheels!? The thrust will push the plane forward, the wheels will be moving quicker than the plane.
Posted : 01/06/2010 12:38 pm
The point you're all missing is that the little tug truck wouldn't be able to pull the plane onto the conveyor belt in the first place as its wheels would turn at the same speed as the belt and it wouldn't go anywhere.
Posted : 01/06/2010 12:40 pm
The crucial point is whether you conceptualise a treadmill (moving under the plane and just spinning its wheels) or an actual conveyer belt which physically moves the whole plane.
Posted : 01/06/2010 12:41 pm
More to the point if the plane falls off the conveyor belt, who should zaskar sue? 🙂
Ahhh, but if you put your luggage on a conveyor belt some of it will turn up in Alacante three weeks later, the rest well end up on the carousel, empty, with your pants snagged on everyone elses luggage
 Tim
IanMunro - Member
LOL!
Posted : 01/06/2010 12:44 pm
 LHS
Posted : 01/06/2010 12:45 pm
IanMunro - Member
LOL!
+1
Does it?
- Plane sits on the conveyor
- conveyor starts moving
- plane moves backwards
- plane power up engines
- plane stops moving, although wheels continue to rotate
- thrust exceeds treadmill speed, so plane moves forwards
- plane takes off
Posted : 01/06/2010 12:46 pm
 Mark
It's just incredible to me that people don;t get this 🙂
+1 for GrahamS rewording of the question to remove any ambiguity.
Now.. imagine you replace the wheels of the plane with little hovercrafts so the plane isn't rolling on wheels at all but is in fact floating an inch of the tarmac...
Posted : 01/06/2010 12:48 pm
Will a plane take off in a windtunnel?
ie if the engines aren't on but you fire wind at it really fast, will it start to fly?
Posted : 01/06/2010 12:55 pm
[i]Now.. imagine you replace the wheels of the plane with little hovercrafts so the plane isn't rolling on wheels at all but is in fact floating an inch of the tarmac..[/i]
What a bit like a Harrier?
Posted : 01/06/2010 12:57 pm
Surely it's not time for this thread to happen AGAIN?!
Posted : 01/06/2010 12:58 pm
 LHS
Yes
Posted : 01/06/2010 12:59 pm
 aP
Of course not because the wheels won't be going round 🙄
Although if it was 4x4 it might, with locked differentials'n'all.
Posted : 01/06/2010 1:00 pm
 Tim
The Southern Yeti - Member
if you could stop it moving backwards without restricting up and down movement...yes
( although i think planes rely on the thrust to help with lift though - maybe wrong here)
It's simple. The conveyor belt is irrelevant.
Posted : 01/06/2010 1:15 pm
If its a very long treadmill then the aircraft will take off ie the treadmill would need to be the same length as a standard runway. However you would need pretty damn good tyres as the wheels would be turning at some speed by the time the aircraft took off.
"ie if the engines aren't on but you fire wind at it really fast, will it start to fly?" Yep that would be one of them glider things...
The engines on a plane create thrust, but dont actually make the aircraft take off its the air moving above and below the wing (as the thrust from the engines propells the aircraft forward) that causes the aircraft to take to the air. Engines are not needed to keep aircraft in the air, they just keep it moving forward enough to keep the air flowing around the wing.
It's simple, the conveyor belt is always irrelevant.
So if the friction in the wheel bearings led to the undercarriage catching on fire, and the whole plane going up in a massive fireball: in that case, only bits of the plane would fly. So the answer is a partial yes, not a full one?
Posted : 01/06/2010 1:19 pm
 LHS
Rotation speed of the wheels would be twice that of normal. Normal take-off speed is in the region of 160mph so the tyres and wheel bearings would need to be rated to 320mph.
Posted : 01/06/2010 1:27 pm
Page 1 / 3
