Pikes compression a...
[Closed] Pikes compression adjust question
[#3897070]
Hi folks, looking for some advice please!!
I am thinking of removing the remote compression adjuster from my 454 coil pikes and swapping it with the manual adjuster off my pair of 426 coils, question is, is it really just that simple or will I encounter any major problems?
Sid
Posted : 22/04/2012 12:32 am
You need to take out the moction control unit and remove a spring form within it, note once you do this you can't go back to the remote option
Posted : 22/04/2012 5:39 am
Swap them over, check oil level, job done.
Posted : 22/04/2012 7:26 am
