One for the weight ...
[Closed] One for the weight weenies, what seatpost?
[#1591906]
as title, what (light) inline seatposts are people using?
Ta
Posted : 10/05/2010 12:01 pm
Thomson Masterpiece. Really light. 220g or so. You might get something in carbon weighing less, but it might cost a bloody fortune.
Mind you, the Masterpiece isn't cheap. I only paid £40 for mine s/h though. 😀
Posted : 10/05/2010 12:04 pm
I've got KCNC, Masterpiece and Extralite posts.
KCNC is good value if you aren't a fatty. I changed the bolts to high tensile steel after I snapped one of the titanium ones.
The Thomson has the best clamp, but it's not a true lightweight post in my book.
Posted : 10/05/2010 12:07 pm
 Keva
KCNC Ti Pro Scandium on my bikes - quoted as 142g.
Kev
Posted : 10/05/2010 12:39 pm
How heavy are you? and what riding?
New Ultimate is about the lightest, or the KCNC as above. Although I reckon the Masterpiece is about the best weight/strength option and what I run myself.
Posted : 10/05/2010 12:46 pm
Syntace P6 here - not superlight but it'll do nicely. Great clamp and comes in 400mm.
Posted : 10/05/2010 12:53 pm
Get an ibeam and fx saddle and post... Really light, and cheap. I'm amazed more people don't use them...
Posted : 10/05/2010 1:07 pm
diamter 27.2mm
Thomson 228 grams (330 length) NukeProof 235 grams (400 Length).
KCNC Ti pro 162grams (400 length) 140grams (350mm.
I use a warhead 31.6mm by 400mm with Ti bolts and it weigh in 260grams (KCNC would be 182grams) but i weigh 95kgs.
I use a KCNC Ti pro cut down on my DH bike, it weighs about 80grams :D, its only 100mm though.
Posted : 10/05/2010 1:11 pm
 mttm
USE Sumo Carbon. OK, it does have 10mm of layback, but that might not be a deal breaker. And it's nice and light (weight: 184g, 30.9 / 300mm), and not too pricey (SRP £85, CRC £75).
I have one on my Intense, it's a good piece of kit.
Posted : 10/05/2010 1:17 pm
Edge Composites 171g (27.2, 400mm)
Posted : 10/05/2010 1:19 pm
Thanks chaps, i'll take a look at the KCNC and the other suggestions.
I'm under 10 stone, FS carbon frame - do the odd race/event etc
 gee
I'd watch superlight posts - the seatpost takes a hell of a hammering and I've seen quite a few of the aforementioned ones in several pieces at various races over the years - the exception being the Thompson.
Having broken a number of posts, I now run a Salsa Shaft on all my mountain bikes - I got into them as I am sponsored by Salsa but now have one for each bike. They're not the lightest but I've not broken one in 3 years of racing.
Posted : 10/05/2010 1:42 pm
Yep and if Gee's experiences with FRM are anything to go by they should be added to the 'avoid' list too!
I used to distribute New Ultimate, and still have a few of their posts to flog. They're very light (my 30.9x350 was 129g IIRC), but do have a 90kg weight limit. Have to say I've not seen one break though, the yokes seem surprisingly tough! They're not cheap though, £170ish.
Posted : 10/05/2010 1:49 pm
depends on the budget and comfort you need/ want.
the kcnc is really good £/g.
as touched on seat post/ saddle systems can be much lighter. either i beam or the custom carbon jobbies - [url= http://www.poshbikes.com/product.php?id=265 ]like this badboy[/url] costs a monkey though!!
Posted : 10/05/2010 1:50 pm
I have the Kore carbon I-beam post and a SDG I-fly saddle on my weight weenie bike. can't recall exact weight, but it was the lightest combo I could find at the time. works great for me, although long spells in the saddle could get a bit tiring, it's a hard saddle. No problem on my SS though, mostly it's ridden out of the saddle anyway
Posted : 10/05/2010 1:59 pm
I-beam is notorious for breaking though! Can usually be got on the cheap mind!
Posted : 10/05/2010 2:35 pm
had mine for a year with no worries. Like I said though, it's on a singlespeed so I don't spend hours in it, more like minutes sweating over it! I don't know anyone else who uses an I-beam seatpost though, so could be I've just been lucky / etc
Posted : 10/05/2010 2:53 pm
Mine lasted 3 rides - the Kore seatpost only grips on 2 very small areas of the rail (~5mm long) - I botched a jump, and it just tore the lip off the rail in those 2 areas.
Posted : 10/05/2010 4:04 pm
