Viewing 5 posts - 1 through 5 (of 5 total)
  • Offset bushing on 650b enduro, anyone done it?
  • deano8
    Is it worth fitting one?
    cynic-al
    Quite a specific question no?
    What is the bike and what do you want it to achieve?
    deano8
    It’s a 2015 Specialized Enduro 650b
    It only has one replaceable bushing and I wondered whether I’d notice the small amount it would reduce the head angle?
    Poopscoop
    Don’t bikeyoke make a conversion which means a normal shock can be fitted…. Also meaning off set bushes can be fitted at both ends of the shock?
    Trimix
    Well that depends on if you can notice the small change in HA.
    That’s up to you.
    I notice 3 degrees going from my Scott to my YT, not sure Id notice 1 degree. Don’t confuse “noticing” it with it “making a difference”.
The topic ‘Offset bushing on 650b enduro, anyone done it?’ is closed to new replies.
