STW review from the homepage
I’m really liking the look of the new SantaCruz Chameleon.
The frame ticks a lot of boxes and it appears that SC’s geometry is finally catching up.
What has really annoyed me is the rear axle spacing.
If you want to run single speed its 12x142mm, but if you want to run gears the rear spacing turns into 12x148mm!
Currently there isn’t a rear wheel on the market that comes as both 142 & 148 OM (though there are some bodges available, ala Wolftooth Boostinater). So this one frame requires 2 rear wheels if you fancy swapping between gears and single speed.
If there’s space to run SS as 142, then they could have kept it for geared too. Why the two standards!
(I guess you could just run the boost wheel singlespeed and keep the mech hanger empty?).
Rant over. What do I win?
