Nasty upshifts on n...
[Closed] Nasty upshifts on new drivetrain - help?
[#1647151]
Replaced worn out drivetrain, new slx cassette and rear mech. New cables. New chain I had unused from a while bck HG-72.
When shifting to a smaller sprocket the chain seems to ride on top of the teeth it is shifting to before falling onto them with a loud clunk. This then feels like a slip at the pedals.
The indexing seems ok just the chain cant find a smooth path from one sprocket to the next like it did on the old cheap SRAM sprocket/chain I had.
Any ideas? Is the older hg-72 not suitable for current kit?
Thanks,
Posted : 27/05/2010 9:13 am
Have you lubed the chain? They often come with a protective wax coating that feels like lube but actually makes the links stiffer.
Also check you've got a 9spd chain, not 7 or 8 (which has fatter sideplates and would not work).
Posted : 27/05/2010 9:23 am
