So those of you who are keenly following the fascinating saga of my Passat will remember that the turbo went recently resulting in loads of oil blowing through the engine amongst other things. Well I bought an old turbo and fitted it – not without faffage – and it kind of works, but I can only get 10psi of boost instead of 14.. however that's by the by.
The car's now taken up smoking. This could be either
a) the oily crud that ended up in the air intake coming through
b) the new turbo's knackered also
c) the car was run low on oil when it was driven home and the rings are knackered.
The smoke was originally blue/white and there was tons of it, now it's just a bit of blue but it smells acrid like burning oil does. It only does it when you blip the throttle, and you only get it when driving when you either floor it or change down to get higher revs. Not really there when driving along.
I was expecting smoke under full throttle because there's now less boost so I need to reduce the fuelling.. but that should be black smoke..?
