I’m right in the middle of doing this. Maxle dropouts arrived, Maxle in the post and 12mm hub on order. I hope it stiffens the back end up, reports are that it does but it’s hard to quantify.
The Maxle dropouts are considerably beefier than the 12mm bolt through versions supplied with the frame but I believe it’s a standard 12mm thread so if you don’t want the dropouts, you can get by with the standards.
There are a few options:
– Std 12mm bolt through dropouts, Maxle, M12 nut
– Std 12mm bolt through dropouts, 12mm bolt through (I do this on my 4X bike using a Superstar axle), stiff but requires tools to undo.
– Maxle dropouts, plain 12mm axle bolted into the threaded maxle dropout
– fully Maxled up
I’ll let you know how I get on, hopefully soon.
