• This topic has 116 replies, 95 voices, and was last updated 11 years ago by LeeW.
Viewing 37 posts - 81 through 117 (of 117 total)
  • Market research… what cranks are you using?
  • StirlingCrispin
    FSA single on commuter.
    Middleburn Uno on ss mtb (chromoly steel)
    Middleburn R7 triple on hardtail (853 steel)
    Shimano XT double (Middleburn rings) and bash on FS (alu). This is my only non square-taper bike.
    Shimano LX triple with mix of Shimano/Raceface/Middleburn rings on tourer.
    Brompton chainset on the Brommie.
    Andy
    XTR m970 x2
    White Industries ENO x1
    Middleburn Rs7 4 arm x1
    XT m770 x1
    njee20
    XTR M985 single
    Dura Ace 7800 double
    Tiagra 4300 double
    aracer
    “gears are for queers” eh, aracer?
    Not at all, ned. I also have another set of cranks with no chainrings which I used with gears.
    ads678
    Deore triple 48/36/26 on the HT 29er
    Deore double 36/22 on the FS
    Kevevs
    5 bolt Race Face turbines – 44/32/22 usual proper mtb bike
    4 bolt race face xc rides – gearing changes all the time. tour bike/pub bike/shopping bike
    octalink ultegra – 53-38 road bike
    all bought cheap through opportunity rather than choice.
    Stoner
    Middleburn sq taper (rohloff cx)
    Middleburn sq taper (ss 29er)
    1995 XT sq taper (1×8 luggage bike)
    On-One SS sq taper (SS pomp)
    Truvativ firex square taper (odd thing half built)
    walleater
    Raceface Atlas FR with single / E13 LG1 guide
    Raceface Deus XC with single / Straitline Silent Guide
    trail_rat
    Raceface turbine – single
    Raceface atlas 100mm – single
    Xt 22-34
    Xt 22-32-44
    Xt single
    Alfine – single
    Sugino messenger , single
    Ultegra 42-55
    Truativ touro – 32-42-52
    How ever i reckon if you made sure it fitted saints , xt and atlas you wouldnt go far wrong.
    edd
    XT M760 run as 22, 32, bash – will probably go to 22, 36, bash – run 9 speed
    XT M780 run as 24, 32, bash – run 10 speed
    porter_jamie
    xt ht2 175 triple on everything, one with 3, one with 1, one with 2+bash
    nedrapier
    aracer: belt drive rings? prop shaft? unicycle?
    _tom_
    Shimano SLX with 1×9, 34t chainring. If I want to use it as a double I’ll have to find some way of removing the stuck chainring bolt. The newer torx fitting bolts seem to be made of cheese and managed to strip completely so had to hacksaw the head off to remove the granny. Far from ideal.
    RustyMac
    Race Face Atlas 22-32-44 on both my bikes, i likes them alot.
    Shimano SLX 22-32-44 on the girlfriends.
    ThePinkster
    SRAM X9 – 2 rings
    Deore – 3 rings
    XTR Mk1 HT – 3 Rings
    XT (circa 1992) – 3 rings
    White Industries – 3 rings
    Bontrager Satellite Nebula – 1 ring (Gates Belt Drive)
    cheburashka
    Deore 44/32/22
    XT 44/32/22
    XTR 42/30
    MrSalmon
    LX triple on the MTB (on its last legs though)
    105 compact double on the road bike
    Alfine 45t single on the commmuter.
    packer
    Thanks very much for the great response everyone.
    Here is a summary of the info so far:
    supersaiyan
    2 more slx double n bash here, one
    Shimano SLX with massively filed down chainring tabs to fit my
    shaman racing bash. Judging by the number of saint and slx cranks on pinkbike with filed granny tabs, this would be something to improve on. May be also worth considering what cranks tend to be used by riders who require chain devices.
    uwe-r
    RF Deuce XC (standard triple)
    Is this the most boring thread ever?
    fathomer
    SLX triple converted to a double, 24/34 rings.
    tang
    Xt double and single(conversion from triples)
    tinman66
    SLX with a triple
    spuddle
    Shimano Slx with a single renthal ring
    richmtb
    XT M770 as a double
    XT M760 as a triple
    phinw
    Truvativ Firex – Single
    Deore – triple
    He means Deus
    No way!
    Me:
    Shimano XT M770 (triple)
    Shimano XT M760 (triple)
    FSA thingumybobs (single)
    packer
    It is a little repetitive I’ll give you that… 🙂
    The results are interesting though. I was mildly surprised by just how much Shimano are dominating the STW crank scene. And also that the split between 1/2/3 chainrings seems to be so even.
    Thanks again all.
    wrecker
    two sets of Shimano XT M770; one single, one double.
    FSA thingumybobs
    Looked em up – FSA Comet. (Dedicated to providing accurate info, me)
    Nope – I’ve found it!
    http://singletrackworld.com/forum/topic/when-digital-photographs-meet-statistics
    Kato
    Shimano M542
    FSA Afterburner singlespeed
    Shimano 105
    joolsburger
    SLX double and bash.
    matther01
    XT 3 Rings on EX8
    SLX 2 Rings on Soul
    DanW
    Rotor 3D running single ring
    The XTR crank for the person who doesn’t want to buy XTR
    rewski
    Xt no conplaints
    LeeW
    M980 and M985, lattter is a triple running as a double for clearance.
The topic ‘Market research… what cranks are you using?’ is closed to new replies.
