The main worry is lack of mid stroke support with the air spring, but will be run firmer than med coil which im currently on, have i any worry here?
While I’ve always had this problem on rear air cans, I’ve never had it on forks.
I could be spouting total rubbish here, but I’ve always put this down to the larger air volumes that fork air springs have compared to rear cans. This results in a much lower air pressure and therefore the spring is less effected by the unequal relationship between air volume and pressure.
The issue I’ve had with rear air dampers is that being heavy, I have to run a very high pressure to get the right support but then it’s too high for the sag I want. Run the air pressure lower for sag and the air spring is too soft and blows through the travel.
The only rear can I’ve ever had that didn’t have this problem is the Bos Devile.
But back to the forks; if you can convert them great but the Lyrik Coil is a lovely fork and while 250g is a decent chunk of weight, you could always lose it elsewhere first and then consider changing the coil in the fork if you still want to save more weight.
