Could be that since you have server the repositories are different?
Different from what?
Far as I’m aware, the only difference between Server and Desktop is in the amount of guff that gets installed on a default install.
Answer largely seems to be – “turn it up”
That’s all a bit GUI and I don’t have one, but the theory might be, erm, sound.
I would assume Ubuntu server doesn’t have any sound preconfigured – it’s not really necessary for a server.
Trousers. You may have a point there. I was just trying to get away with having the bare minimum for a short boot time. I’ll have a rummage.
try installing the pulseaudio package.
[quote]Looks like you might need to add yourself to the audio group?[/quote]
I’ll try those too. Ta.
do the default Ubuntu install
Yeah, I hear you. But part of the reasoning for doing this though (other than an irrational desire to play Jet Set Willy) was to use it as an opportunity to play with Linux. I’m not completely green, but I need more experience and familiarity than I currently have. I’m trying to remove my reliance on a GUI as much as possible; I’m not necessarily aiming for ‘easy’ so much as getting a better understanding of what’s going on.
Food for thought, thanks all.
