Running a Thompson (as I said before)
Had an issue with the actuator – was replaced no quibbles and quite quickly. Only other issue was the grub screw in the lever. Best thing about it is that you fit the cable at the lever rather than the cartridge end so it’s a lot easier. Reliability has been good other than the cable slip and actautor (which happened as soon as I got it – if it’s gonna go it’ll go quickly). Again, thompson will fix / replace with no quibble whereas KS won’t. That for me was the deal breaker
Edit. I’ll be fitting a fox transfer next year but only cos I’m a tart and want matching kit
