Kenda 8 block tyres
[Closed] Kenda 8 block tyres
[#3398395]
Would Kenda 8 block tyres will be ok and suitable for winter riding, like wet root/rocks and mud?
Any experience?
Posted : 27/11/2011 9:33 pm
Small Block 8s?
Not normally winter tyres TBH - you may get away with one on the back but not the front
Posted : 27/11/2011 9:36 pm
Definitely not any good in muddy conditions or wet conditions. Very fast in the dry though. Raced on them in the dry successfully, failed horribly in the wet on them too, they're definitely a dry condition tyre (which is what they're sold as)
Posted : 27/11/2011 9:51 pm
Is this a troll???????????/
Posted : 27/11/2011 10:17 pm
No mate. Not if you want any grip at all in soft conditions.
For our area it's best to get something with fairly tall, widely spaced nobs that you can run at low pressures so they flex and shed mud. I'm using a medium compound Maxxis swampthing on the back at 26 psi and I can actually climb muddy trails no problem (apart from the usual wheezing) 🙂
Posted : 27/11/2011 10:25 pm
No good in the wet & useless in mud. Try Mountain Kings instead.
Posted : 27/11/2011 10:39 pm
Napalm, I had MK's on for a while then I tried Maxxis HR's. The difference was truly fantastic in mud, would never go back and now Maxxis are my favourite tyres. I do like Panaracer Fire XC Pro's too though, equally as good but slimmer (2.1) - maybe even better as they cut through mud. I'd recommend you swap if possible.
Posted : 27/11/2011 11:18 pm
Thanks for the answers, will avoid Kenda tyres for winter riding.
@mudpup, the reason I asked that the winter is coming and I will be riding most on the road on my MTB with a few quick blast at local woods in my area so I ask for advice, so calm down boy 🙄
Posted : 28/11/2011 12:01 am
Ace in the summer but no, show them a root & you'll be on your backside pretty quickly. Nevegal / Blue Groove are ok though, but bit old hat nowadays. Maxis Minions look very good.
Posted : 28/11/2011 12:09 am
rainbow - Member
They do make more than one sort of tyre.
Posted : 28/11/2011 12:11 am
Then I would definitely get some slicks for road and just swap for a proper grippy tyres when you fancy a play in the woods. Mind you I bumped into cando David today riding stuff that scares me on his singular swift shod in summer tyres, maxxis aspen 29s I think.
Posted : 28/11/2011 12:19 am
