I've really br...
[Closed] I've really broken my new Forks. Help!
[#3366961]
Fox Float RLC FIT Kashima...
Tried to service them myself...
I've over tightened the foot bolt and it's snapped the rebound piston-rod thingy...
Bugger. Will mojo be able to fix it? Will it cost a lot?
(I actually had a little cry in the garage or was it oil in my eye 🙁
Posted : 18/11/2011 10:39 pm
Yeah can be fixed, but you'll be buying a new damper. Do not expect it to be cheap
Posted : 18/11/2011 10:41 pm
You'll need to buy that bit of the damper only not a whole one assuming it's like it was when i did the same to some 36's.
Posted : 18/11/2011 10:42 pm
Yes,VERY yes.
Posted : 18/11/2011 10:43 pm
might be lucky then. I did the same to some very old 125 Rs, needed a damper (I got lucky and got a 2nd hand one off TF Tuned though)
Posted : 18/11/2011 11:03 pm
Have a word with Loco from the forums, www.locotuning.co.uk; he may be able to sort out a solution for you.
Posted : 18/11/2011 11:14 pm
I have done something similar, ruined the threads at the bottom of my rebound damper (36 van r.)Give LoCo a ring, i'm going to send in my damper and he is replacing the base valve (parts around £25), so you may be luckyish too.
Posted : 19/11/2011 8:06 am
Now buy a torque wrench 😐
Posted : 19/11/2011 9:27 am
Now buy a decent torque wrench 😐
The suggested torque is so low you'll always overtighten without one imo.
Thanks for the comments guys.
Can anyone recommend a torque wrench which will do the job and not cost he earth?
Posted : 19/11/2011 7:51 pm
You didnt scrimp on bike parts so why scrimp on bike tools?
Buy a half decent one and do ther job properly..... 😉
Posted : 19/11/2011 8:32 pm
I like my BBB one. The supplied allen key heads (and Torx25) all seem much better fit than any other tools I've tried (including park tool)
Posted : 19/11/2011 8:34 pm
I've done that to a mate's fork. Repair didn't cost any more than a service.
Posted : 19/11/2011 8:40 pm
T-p26: thanks. Do you have experience with a torque wrench ? Which one do you have ?
Honourablegeorge: cheers mate. Made me feel better that it's not going to cost the earth.
Posted : 19/11/2011 10:56 pm
Did the same to some talas's, sent the damping unit off and had the offending article replaced by mojo. Wasn't eye wateringly expensive either.
Posted : 20/11/2011 12:19 am
thread resurrection!
ive just done this today, glad im not alone 😆
have emailed si, awaiting a reaply!
what sort of cost was it in the end? i have also snapped off the rebound rod too, along with obviously the outer screw shaft....
any ideas on pricing? was it a whole new fit damper, or just a part of it?
cheers! put me out of my misery pleaaaaase 🙁
Posted : 27/11/2011 9:00 pm
