Bearing replacement...
[Closed] Bearing replacement Heckler 6.1
[#3366982]
Can anyone talk me through bearing replacement for the new style heckler swing arm - the one without the pinch bolts.
Thanks
Posted : 18/11/2011 10:46 pm
undoe pivot - massive allen key
remove swing arm
the bearings are enduro max - VERY fragile
worth getting the tool or blind bearing puller
then **** em out. Make sure the outer race is being hit not the inner as the bearings will fly everywhere and you will be left with the inner race stuck.
Use a bolt and washer arrangement to press them in
look at the tools for an idea
http://www.santacruzbikes.co.uk/list.asp?cat=19
Posted : 19/11/2011 7:34 am
Thanks for that. Simple really! Do you know how much torque the pivot bolt requires? All seemed fairly loose when I dismantled it.
Posted : 22/11/2011 11:15 pm
