4 answers – only one correct
Iainc has it. You can’t change the reach on a frame. It’s got nothing to do with where the bars are
Where is the face palm emoji when you need it? 😉
The replies from Northwind and me did not mention the handlebars and we were correct because you absolutely CAN change reach (and stack and effective top tube) on a frame by changing the vertical height of the fork. This can be done by changing the fork length (or the lower headset cup height) or by changing the head tube angle (with an angleset).
The lower the vertical fork height, the more the frame rotates forwards, decreasing stack and increasing reach. However if you purely use an angleset to do this the upper cup rearward offset cancels out your increased reach.
It’s all right angle triangles. Think.
