I want my seatpost ...
[Closed] I want my seatpost to fit better to prolong the life of....
[#3712987]
I’m contemplating gluing my seatpost into my Giant Advanced carbon frameset. Bear with me on this.
The top part of the seatpost has not cracked but is flexing, like a carbon fishing rod, hence the paint crack and no carbon crack. (I’ve removed paint from this area to verify this). The lower, assumed paint crack, is a result from the bottom of the Thompson seatpost. The frame does not have any noticeable flex or creak even with my 16.5 stone bulk.
I’ve changed the seatpost today, from a Thompson 410mm, to a Gusset XXL – 450mm long. That’s 180mm in the frame / 270mm sticking out. However with both this and the Thompson post you can pivot the post in the frame, before clamping, indicating a slightly larger diameter to the seat tube below the “clamping zone”. Hence the corresponding paint crack lower down on the tube. I want to eliminate this to gain full benefit of having more seatpost in the frame . I was thinking of a low viscosity epoxy adhesive, maybe too thick, or alternative a carbon assembly paste. I’ve also got to get it past the “clamping” zone which will act like a wiper.
Or just ride it until it breaks.
Posted : 25/02/2012 11:36 am
I would suggest your frame is already broken.
maybe get a quote from a carbon repair place who may be able to overwrap it or how about a warranty claim? What is the warranty on the Giant frames?
Posted : 25/02/2012 11:56 am
That's not just cracked!
That frame is no more!
It has ceased to be!
It's expired and gone to meet it's maker!
It's a stiff! :irony:
THAT IS AN EX-FRAME!!
Posted : 25/02/2012 11:59 am
The nature of the damage has been progressive for over a year and was viewed in Sept 2011 by an LBS as cosmetic.
Giant's warranty is not worth the paper it written on. As I've changed a component (the seatpost) the frame is not covered under warranty. It also only covers manufacturer defect, ie cracking in straight lines.
Trust me. If the frame rode any different to what it did from day one then it would be straight in the skip.
Posted : 25/02/2012 12:47 pm
I really wouldn't ride that if I were you...
Posted : 25/02/2012 12:51 pm
pjm84 - Member
Your LBS has proper facilities for analysing this? I'm impressed. We didn't have anything like that in the LBS I worked in.
Posted : 25/02/2012 1:05 pm
Sept 2011 by an LBS
ah the local bike shop. Well known for it's expertise in failure of composites....
Contact a carbon repair place for a quote. They will be able to give you some proper advice and have probably seen such problems before.
Posted : 25/02/2012 1:07 pm
that is DEAD! the resin has started to break. (its brittle)
Posted : 25/02/2012 1:10 pm
Will ask a carbon repairer on Monday.
The LBS eye test! Giant warranty did the same. i.e visual.
Once I got the bike back I picked the paint away to see if it corresponded to a crack.
Posted : 25/02/2012 2:48 pm
Glue a long carbon post in there it'll be reet 😉
Posted : 25/02/2012 3:00 pm
That's ****ed ,unless you can bond a very long seat post in then I would start shopping for a new frame.
Some nice deals at Planet X at the mo.
Posted : 25/02/2012 10:55 pm
