I have some hope mono m4's, 180/160, and mono mini's on my other bike. I 've used avids, formulas and other hope models in the past. The mono M4's and mini's have similar power until you pull them harder and the M4's have more ultimate braking power, more than I really need. Compared to the avids and formula's there is a greater range of applicable power, modulation, before you reach the maximum braking power so they have much less on/off feel and need pulling all the way and reasonably hard if you want to stop fast.
Floating rotors won't make a difference, bigger rotors will make a big difference though. I have braided hoses on some of my brakes, they don't make a noticable difference but look good and flex much better for routing them around the frame. A good bleed, make sure there is plenty of pad and no surface contamination on the pads and rotors, use a good degreaser for brakes if there is. You could try sintered pads if you aren't already using them, and maybe larger rotors.
