Eyup all, since this seems to be the thread for building works does this quote for drainage works seem to be in the ballpark? (I’ve a horrible feeling that the answer will be ‘yes’)
Repair: Sonar trace 4.9m downstream of manhole, excavate and replace 2m section of pipe work including junction and pipe section upstream of junction.
Jet pipe to clear debris, re-survey in preparation for lining.
Reline from manhole downstream for a distance of 2m, insert patch liner at 9m downstream of manhole 1. Replace vertical pipe from junction to existing soil pipe. Remove all excavated material from site, reinstate area of excavation.
Depth of excavation is between 1.5 and 2m. Pipe is 100mm diameter and obviously knackered.
Quote was £1650+VAT E.mids
