Been given a hedge cutter (Black and Decker), which works fine. I have now noticed that one of the bolts on the blade is missing. After a bit of an internet search, I can’t find one..(the bolt assembly has a special washer to act as a spreader between the blades, so I can’t just replace it with a simple bolt as it stops the blades moving. experiments with not doing the bolt up tight have been unsuccessful…)
Was thinking of nipping to the tip tonight and seeing if the big pile of broken ones has the right bolts, otherwise, where can I get something like this from?
