Hi.
I have some movement in the bottom bracket of my stock setup meta 55.
The non driveside bolt is torqued to spec.
There's a knocking coming from the bottom bracket when pedalling and there's movement apparent when applying lateral pressure through the cranks, by hand.
Question is, is it goosed? The chainset seems OK and shifts sweetly enough, so perhaps an "upgraded" bottom bracket is the answer (don't even know if this is possible with GXP)?
Reluctant to replace with X,Y or Z flashiest/ latest thing as I have an imminent roadie commitment.
This is 3mths weekend use, btw…
