GXP BB replacement
[Closed] GXP BB replacement
[#6296062]
anyone managed to replace the bearings on a GXP BB?
I would guess that they are meant to be replaced as a unit but Shimano say that about they'res and that isn't true. Any one done a GXP?
Posted : 25/06/2014 9:18 pm
Would this allow me to use my Shimano spec BB shells.
http://www.ebay.co.uk/itm/HOLLOWTECH-2-TO-SRAM-GXP-EXTERNAL-BEARING-BOTTOM-BRACKET-CONVERTOR-SHIM-/161324667489?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item258fb31261
I know it says but it all seems too easy.
Anyone
Posted : 25/06/2014 9:24 pm
Come on. Surely I am not the only one to have come up aginst these mechanical abortions.
Posted : 26/06/2014 6:44 am
That adapter would probably work. Hope do something similar for their BBs
Why not just buy a replacement sram GXP BB though?
Posted : 26/06/2014 6:52 am
Yes, but I ended up carrying on buying gxp bottom brackets every 6 months on one bike and on the other changing the chainset.
Posted : 26/06/2014 6:54 am
It looks a bit like the hope one that's about a £9. They had an installation video on their site a few years ago.
Posted : 26/06/2014 6:56 am
I have swapped bearings in the drive side. They are common off the peg size. Not tried the non-drive side yet but have found a source. No reason to beleive it would not be a straight swap though. Just remove the circlip, press out, press new one in, replace circlip, job done.
I can't remember the exact sizes at the mo but the link below "could" be the bearings needed
Non-drive side
http://simplybearings.co.uk/shop/p20000419/ENDURO+MR22372RS-E+Sealed+Flanged+Extended+Inner+Deep+Groove+Bearing+22x37x7/10mm/product_info.html
Drive side (can't remember if it was 24 or 25mm internal dia so either)
http://simplybearings.co.uk/shop/p20000200/ENDURO+68052RSMAX+Rubber+Sealed+Max+Type+Deep+Groove+Bearing+25x37x7mm/product_info.html
or
http://simplybearings.co.uk/shop/p152853/ENDURO+MR2437LLU+Rubber+Sealed+Deep+Groove+Ball+Bearing+24x37x7mm+inc+2+Nylos+Rings/product_info.html
Posted : 26/06/2014 8:36 am
I've changed the bearings in my old gxp 3 times. I wouldn't do it again though as the cheap hollowtech 2 BB I replaced it with has out lasted it 3 fold.
Posted : 26/06/2014 8:43 am
Yup - the Brightline one works perfectly - just fitted one myself with my X01 cranks in an Shimano BB. Well worth it!
Posted : 26/06/2014 8:50 am
The Hope one will only work with a Hope BB, as Hope don't use the top hat arrangement.
I used to replace just the bearings in Shimano BB's but a couple of years ago they changed the bearing width to a narrower, non-standard one to accomnmodate wider seals.
Your widget above looks good - I think I've got some spare bearings and a knackered GXP so I might get one of those and see what fits, as my last GXP only lasted 3 months 🙂
AndyRM - did you have to remove the top hat?
Posted : 26/06/2014 9:57 am
Adviser: I've not clicked any links or read any posts...
I got some GXP cranks a short while back and had a similar issue, no pennies at the time for a decent BB so I bought one of the £5 adapters.
They do work, sort of. Sometimes the crank spins inside the adapter (rather than the BB bearings spinning), and as such incurs friction making pedalling a bit more laboured.
I bit the bullet, bought a hope BB with the GXP adaptor. Much better and will almost certainly last me a lot longer.
I have a feeling, as the GXP and HT2 crank-tightening system puts different loads on their BB's, that a GXP crank correctly tightened will kill an HT2 BB.
Posted : 26/06/2014 11:04 am
Thanks for the link to that Brightline shim - been looking for something like that for a while.
Posted : 26/06/2014 11:12 am
When a new GXP BB is £20 from Halfords I replaced it all rather than trying to replace the bearings alone.
Posted : 26/06/2014 11:32 am
Conan257 - Member
A GXP crank correctly tightened should perfectly preload a Shimano BB. But getting it all right might be easier said than done.
I've dealt with this problem by deciding never to buy a shitey GXP crankset ever again.
Posted : 26/06/2014 11:38 am
I'm agreeing with the last sentence above but its a bit late now. I have a perfectly good (of course that relative) XT BB that maybe worth a try with one of those thingies.
Common sense says buy something that uses normal industry standard bearing as they are cheaper and better quality if sourced correctly . Ta people
Posted : 26/06/2014 6:00 pm
Well 2 minutes saw the shagged bearings out of a HT 11 BB. Off to the bearing factors tomorrow.
Posted : 26/06/2014 8:32 pm
