Planning to upgrade my 26″ MTB wheelset. Should I choose 650b instead of 26″ for the upgrade?
I am running a pair of Mavic Crossone with Schwalbe 2.1″ Big Apple. Will upgrade to a custom build – Hope Pro4 hubs, 32 spokes, Stan Crest Aluminum rims. Preferred tyre will be schwalbe Marathon Supreme 1.6″. I mainly do XC, touring and trekking on half/half hilly/flat areas, kind of 50% paved surface, 25% badly maintained concrete road, 5% off road, the rest are mix of gravel or sandy trails.
I checked with the bike manufacturer, both my frame and the fox performance 100mm travel air fork will accept 650b with 1.6″ tire on. The 650b wheel+tyre diameter will be 12mm longer, circumference will be roughly extended by 2% compared to my current 26″ setup. The bb will be 6mm higher than I currently have.
I know 26″->650b is an endless debate. But I will upgrade my wheelset any way. The price tag for 26″/650b upgrades are almost the same. Should I choose 650b for better roller-over, curb hopping ability, potentially more comfortable ride (650b tyre holds more air), in the expense of 200g heavier set up, 6mm higher bb?
