Afternoon
Following on from my question about mountain bike cassettes on my kaffenback, I have a new problem.
The MTB cassette won’t fit on the freehub, totally different size.
What I want to know is, are all freehubs fitted the same way,ie is the fixing bolt one standard size? So I can just buy the appropriate freehub body and swap them over?
Cassette is shimano deore hg62-10,wheels are older planet x a57 pros with planet x hubs.
Its a shimano freehub, not campag, a shimano cassette came off it.
I know I can get one that fits my new cassette, I just want to check that the way all freehub bodies screw on are the same,ie there’s no fancy fitting needed, just the correct size freehub.
Edit, scotroutes, I saw those but the one I need is sold out
Yeah that’s what I thought as well, but its nowhere near.
The splines are all the same spacing,its the freehub diameter against the cassette diameter that’s out.
0.8mm difference.
Now,normal freehub at held on by the long threaded bolt right?
But there’s no way of doing that here, that I can tell,the planet x freehub just slides onto the axle shaft and is held on by the locknut.
Can anyone see a solution to this other than a new hub/wheel?
This was supposed to be a cheapish conversion 👿
I didnt pick up on that the first time i looked at the link scotroutes, i thought they were just selling what i already have but yeah they do look like they have the ” not so deep” splines, but all out of stock. I’ve sent them an email, I’ll wait and see what they say,nothings ever easy huh.
Some early shimano 10 speed road hub bodies looked like yours and would only work with shimano 10 speed road cassettes. These bodies have taller splines to avoid wear.
From what I remeber at the time your could not even get a tiagra 10 speed cassette on the wheels only a higher end one. But all this was a few years ago
Some Easton wheels also used this fatter body that would only ever take a 10 shimano road cassette
For my own use I had a mate machine down the alloy till it was the same as everything else and it’s been fine
And you will have to have a hub body for your wheels from on one not just any hub body
Yep, early Shimano 10 speed wheels had deeper splines to avoid the cassette biting in. Didn’t realise any after market companies did it (why would they?), but certainly looks like they did!
Thanks everyone, I’ve sent a few mails off enquiring,I’ll let you know the outcome.
Edit,mallorcadave, have you stripped a superstar one? Does it slide onto the shaft and then held on by a locknut? Like my pics?
Ah, well, I don’t think I saw the original thread, but my assumption was that you were changing the freehub because the bearings were shot, if you still have the old body you could fix it. There’s not a lot else to go wrong.
If that’s the case, you can knock out the old bearings and press some new ones in. There’s a sleeve between the two bearing that you can move to the side to get a tool on the inner race and knock the old ones out. 21mm socket was the size I used to press the replacements in if I recall correctly.
edit –
Glad you got it sorted, i woke up this morning realizing that the bearings on the superstar hub are probably a different size because its compatible with a 12mm thru axle! Same body different bearings methinks 😕
Posted 9 years ago
Viewing 30 posts - 1 through 30 (of 30 total)
The topic ‘Freehub body compatability’ is closed to new replies.
