My rear formula oro k18 gets to the point where the lever goes close enough to the bar to touch my other fingers (i brake with one finger), this is my signal that i need to change the pads.
Replacing the pads cures it, but am slightly conscious that i am replacing the pads before they are fully worn out. If i have the reach adjustment any further from the bars i can't reach the lever that well when it's in the off position. i.e. there is too much range of travel when the pads are slightly worn, basically.
They don't need bleeding – it's not squishy, once the lever gets to full lock position it will not go any further.
What I effectively lack is the distinction between reach adjustment and bite point adjustment that e.g. the new hopes have got.
The springback action has not been quite as 'snappy' as when it was new since i crashed at CyB and rebuilt the lever, but other than that it's fine.
what i wonder is, is there a quick fix to make the bite point move further out as the pads wear?
Thanks
