been running mtb “touring” 9 speed triple for a few years on my kinesis pro6 with ultrega sti’s and a standard mtb hollowtech bearing set up, xt front and rear mechs
need a bit of jiggery pokey with a wooden wedge to hold front mech in correct position to get cable tension correct and have in line adjusters to keep it shifting smooth – at the limits of what the front mech will do and won’t absolutely always drop to granny first time if set to avoid chain rub on big ring/smallest rear but can ride up virtually anything without any mtfu
pretty sure won’t work with 10/11 speed due to different pull and will be going compact on a new build
edit wooden wedge isn’t permanent – just to hold mech in correct position when clamping cabling
