Wondering about doing this. I have a mukluk frame that’s currently running 29er rims on 135/170 hubs.
Quite fancy building up some lightbicycle carbon rims – I have some of their road wheels that are nice, and I like the rim profile
They do centrally drilled 32s or dual-drilled (2x)32s, both in 90mm wide rim only. I have a nagging feeling that just using the centrally drilled rime would maybe not support the edges of the rim that well, and might overstress “something”.
If I use a dual-drlled rim, the holes are 19.5mm either side of centre. If I build using these going from flanges to the “same side” offset holes it seems to me that there’s not going to be that much triangulation on offer (I doubt it’s that far removed from a conventional wheel but somehow feels wrong to me) and so I’m wondering if I should go to the opposing side instead. That, however, is a LOT of angle and not sure if the nipple would sit right in the rim
QUestions, then:
1) 90mm wide sounds like a lot – that OK for general riding ? (no snow, not much sand but plenty of mud)
2) Central lacing: that’s 45mm “unsupported” either side to the edge of the rim – is that a bad thing ? (I have a feeling that some surly rims have offset drilling which presumably leaves more than that at one side ??)
3) If I went for the dual drilled, do I build like / \ or like X ?
4) Any top tips for building ?
