Do you mean the windows have broken, or do you just mean that the window isn’t sealing anymore & so you have condensation forming between the two panes that make up the double glazing?
If it’s the latter, then I wouldn’t say it is an urgent fix at all. They obviously won’t be working as well at keeping the heat in & the cold out, but apart from that, there is no real issue that I know of.
You should just be able to replace those panes, if required, rather than having the whole frame & all window panes replaced.
That can work out a lot cheaper, obviously, and might provide a decent temporary fix.
Sites like this one:
http://www.clearviewbuyonline.co.uk/glass-glazing.asp
have a ‘designer’ option so you can get an idea of how much a pane is likely to cost to replace.
